#118555 - 30/09/2002 13:27 Empeg buggin out
oliver
Ok, I was waiting to pick up a friend and i loaded up pacman while listening to music. Got to the 3rd level and died, loaded it up again. This time i started playing pacman with the remote. About half way through the level, the empeg brought the track screen to the top, and then it started switching between aux in and the player app very quickly. Had to remove the empeg from the cage to correct the problem.
Now whenever i load up pacman, it will start switching between the player and aux in. I updated to the latest version of hijack. Any ideas?
#118556 - 30/09/2002 13:38 Re: Empeg buggin out [Re: oliver]
Happy Birthday Daria
The same problem gpsapp was having in another thread. I guess this lends credence to the "hijack interaction" theory.
#118557 - 30/09/2002 13:49 Re: Empeg buggin out [Re: Daria]
oliver
Its a pretty weird problem. Hopefully somebody will take a look at it sometime in the future
#118558 - 30/09/2002 13:51 Re: Empeg buggin out [Re: oliver]
Well, I have an idea for what to do, but I've only gotten it to happen one time ever, which isn't really conducive to debugging it.
#118559 - 30/09/2002 13:56 Re: Empeg buggin out [Re: Daria]
jaharkes
I've been looking at the diffs between v293 and current, as I'm running 293 and definitely do not see this problem, but haven't noticed anything in particular yet.
At least I don't have to look at possible serial port interactions anymore, I can hardly believe empacman is using the serial port
#118560 - 30/09/2002 14:34 Re: Empeg buggin out [Re: jaharkes]
oliver
So basicly if i downgrade hijack to 293 my problems will go away? I think i have a copy on my desktop of 293, maybe i'll give that a try.
Lastnight when i first noticed this problem, i was running 294, and i think the only change between 293 and 294 was the last empeg meet message. Maybe i'll still try and downgrade to 293 and see if i still see these problems.
#118561 - 30/09/2002 14:58 Re: Empeg buggin out [Re: oliver]
genixia
Naah. This quirk appears in earlier versions of HJ too. The ioctls are still immature, and Mark has suggested that they will be reworked sometime once the climbing season is over...
#118562 - 30/09/2002 15:35 Re: Empeg buggin out [Re: genixia]
Greetings!
Actually, it might not be a direct interaction. I have noticed this on my player as well, but I always wrote it off to too many mods (button hack, etc). Mine alternates between different sources (no tuner, so just player and aux). I am running hijack 291. Usually, I just hit the pause button to break the cycle.
#118563 - 30/09/2002 16:04 Re: Empeg buggin out [Re: oliver]
Warp10
Loc: Germany
You might also want to take a look at this thread.
(Sub-heading: 'Strange behaviour')
---------------------------- MK1: 00314 (4GB) MK2a: 030103104 (30GB) Installed in a BMW 323ti
