#117678 - 23/09/2002 11:47 Question about boot-up
Burgin
I was wondering,how does the kernel know how long to wait for the hard disk to respond during the boot-up.
#117679 - 23/09/2002 11:52 Re: Question about boot-up [Re: Burgin]
It's hard coded to wait a certain number of seconds before giving up. I don't know how many seconds, they keep changing it with each software release.
After two hard disks respond, it continues the boot process. If only one hard disk responds, it waits a few more seconds for a second one to respond, then continues.
For this reason, a two-drive player will boot quicker than a one-drive player (since it continues the boot process as soon as two hard disks are found).
If you have a one-drive player, it is possible to hack the kernel so that it doesn't even bother to wait for a second drive. There were some features related to this in prior hijack versions, but I don't know if they're still there.
#117680 - 23/09/2002 12:00 Re: Question about boot-up [Re: tfabris]
303
Loc: Germany
If you have a one-drive player, it is possible to hack the kernel so that it doesn't even bother to wait for a second drive. There were some features related to this in prior hijack versions, but I don't know if they're still there. they are! "Hard Disk Detection" in the hijack menu!
#117681 - 23/09/2002 12:01 Re: Question about boot-up [Re: tfabris]
Burgin
I assume you were referring to the factory kernel. Is HiJack different? Does it not wait as long?
#117682 - 24/09/2002 03:14 Re: Question about boot-up [Re: Burgin]
As far as I'm aware, if you set Hijack to 1 Drive mode, it will wait for the first drive to appear, forget about waiting for another and carry on starting up. It used to make a great difference.
#117683 - 25/09/2002 21:14 Re: Question about boot-up [Re: Burgin]
Hijack actually waits longer for the first drive to show up (no difference in actual time unless no drives are present..), and has a menu item to force it to NOT wait for a second drive. The menu item only appears on single-drive units, not dual-drive players.
