Page 2 of 2 < 1 2
#117315 - 25/09/2002 23:56 Re: need new display board asap for broken nipple fix! [Re: tanstaafl.]
There's also the possibility of the broken capacitor on the back side of the board.
My point is that lots of things besides the fill nipple can make the display go bad. When he said he broke the fill nipple, I assumed he'd visually verified that it had actually broken off. Now it seems from his last description as though the nipple is intact.
I think I'll update the image in the FAQ to more clearly indicate that the illustration is supposed to be of the missing nipple, not of the normal discoloration of the glass on the corner.
Edit: I take it back. I think the images and text are clear enough as they are.
#117316 - 26/09/2002 01:43 Re: need new display board asap for broken nipple fix! [Re: ravetek]
It's pretty obvious when the nipple breaks - it comes right away from the display and you're left with a hole there instead! If the nipple is in place and there's no sign of a crack or any missing glass then you're barking up the wrong street entirely, and Tony's fuse comments are almost certainly the real problem. If that's the case, after your earlier comments, I will slap you
#117317 - 26/09/2002 09:35 Re: need new display board asap for broken nipple fix! [Re: rob]
lockuplever
Loc: Tucson, AZ
Touché
Steve
#117318 - 26/09/2002 10:45 Re: need new display board asap for broken nipple fix! [Re: rob]
Mach
Loc: Texas, USA
Oooooh, someone get a pic of the slap for the FAQ. Tony can file it under "How do I contact Rio/empeg if I need support?"
#117319 - 27/09/2002 08:53 Re: need new display board asap for broken nipple fix! [Re: ravetek]
bbowman
Loc: Virginia, USA
If you aren't going to fix it, I'll buy it off you in it's present condition. What would you say... $150 ?
Brent
RioCar MK][a 20GB+80GB
'96 Saab 900s (Not any more)
Page 2 of 2 < 1 2
