#116496 - 15/09/2002 19:59 No sound
Phireman19
Hey guys, another question.
Besides the problem with my remote, A couple of times in the last few days, I was listening to my empeg in my car, and all of a sudden there was no sound. The empeg was still playing, but no sound from my speakers, My amp was still on.
I had to pull the empeg out and put it back in the sled and then it started working fine again.
Any ideas??
#116497 - 15/09/2002 20:13 Re: No sound [Re: Phireman19]
Loc: Los Angeles, CA
what version of the player software are you using? b13?
#116498 - 15/09/2002 20:20 Re: No sound [Re: image]
Phireman19
Beta 11
#116499 - 15/09/2002 20:35 Re: No sound [Re: Phireman19]
probably the "stuck jiffies" bug. upgrade to b13, and you should be fine.
#116500 - 15/09/2002 20:51 Re: No sound [Re: image]
Phireman19
ok, i'll do it.
Is there a quick guide you can recommend for me on how to upgrade it, I am still new at this ?!?!?!?!?
Thanks!
#116501 - 15/09/2002 21:02 Re: No sound [Re: Phireman19]
#116502 - 16/09/2002 01:15 Re: No sound [Re: Phireman19]
Anonymous
Unregistered
It might have been that your player wasn't in the sled all the way. I get this sometimes because my player doesn't fit in the sled easily because of the shape of my dash. It's in enough to get power, but the audio outputs aren't making contact.
#116503 - 16/09/2002 04:35 Re: No sound [Re: Phireman19]
DarkStorm
Loc: Pompano Beach, Florida
Another thing you might want to consider is the amps.
I've had my amps decide all on their own before that they just want to turn off. Almost like they lose their 12v switch signal that the stereo supplies. Turning the system off and then back on made them turn on again.
Don't blame the empeg so quick. It might not be its fault.
Steve DarkStorm Designs
#116504 - 16/09/2002 05:41 Re: No sound [Re: Phireman19]
The amp would be my guess as well, but usually something like what you describe happens after a while of listening, and isn't really fixed that easily.
For example, on my trip back to the parents' house, 2 hours and 20 minutes, I'll listen to my empeg at about 0dB all the way. around the 2 hour mark, sometimes the sound will cut out completely. This is because the amp has overheated and shut off. All I need to do is turn off the empeg and wait about 5 minutes for it to cool down. I also turn on the lower fans of the A/C
You probably have a different problem, but it could be related.
#116505 - 16/09/2002 06:55 Re: No sound [Re: Dignan]
Phireman19
I had only been listening to it for about 45 mins when it shut off. Then the other day it shut off after about 2 mins.
I checked to see if the amp was on, and it was,.. so not the amp. The empeg was all the way in sled also.
#116506 - 16/09/2002 07:03 Re: No sound [Re: image]
In my experience, when the jiffies bug occurred, it still played music, it just wouldn't accept input. So I don't think that's the case here.
#116507 - 16/09/2002 08:03 Re: No sound [Re: Phireman19]
Anonymous
Unregistered
Maybe you're just going temporarily deaf? When's the last time you've been to an ear doctor?
Or it could be loose wires, like an RCA cable not in all the way.
#116508 - 16/09/2002 09:36 Re: No sound [Re: Phireman19]
bodybag
Loc: Southern California
The same thing happens to me about once a week. I'm running b11 still too. Also happens when the player boots up initially some times. Everything seems normal just no sound. My amps are clearly still on, it's the Empeg for sure. I'll also upgrade to b13 and keep the board informed of any further occurances.
Bodybag - So Cal
Not a Whiner any more!!!
#116509 - 16/09/2002 12:48 Re: No sound [Re: ]
Phireman19
Huh?? What?? I can't hear ya???
LOL
RCA's are fine.
I am gonna upgrade to 2.0b13 and see if that does it!
#116510 - 16/09/2002 13:30 Re: No sound [Re: wfaulk]
schofiel
No, on both my Mk1 and Mk2 it latched up the player either completely, or the player stopped and the visuals continued. Was the "W" displayed top right on the screen when the music stopped?
#116511 - 16/09/2002 13:42 Re: No sound [Re: schofiel]
Phireman19
No, everything appeared normal, just wasn't getting any sound.
I just upgraded to 2.0b13 and Hijack 293, so we'll see if that fixed the problem.
