#116254 - 13/09/2002 08:56 discspace info w/ emptool v1.03
raphael
Loc: Austria
Is it possible to get discspace information using emptool v1.03 under Linux?
I know that the beta 2 version print that info on start, but since I've got some
troubles with the beta version (hang on "Loading visuals ..."), I wanted to downgrade.
Now I can't find out how much space I've got left on my radio :-(
Raphael Wegmann
raphael@psi.co.at
#116255 - 13/09/2002 11:01 Re: discspace info w/ emptool v1.03 [Re: raphael]
but since I've got some troubles with the beta version (hang on "Loading visuals ..."),
This is a serious problem that needs to be fixed. Forget 1.03, there's something bigger that's going wrong. Assuming that the version you're running is 2.0 beta 13, Your player should not hang on "Loading Visuals".
Have you gone through each and every bullet point here to make sure you've done everything right with regard to the beta13 software installation?
#116256 - 13/09/2002 11:43 Re: discspace info w/ emptool v1.03 [Re: tfabris]
rockstar
THis is a problem i had when i first got my player. WHat fixed it for me was going completely back to the last consumer release, then installing teh dev rrelease of that kernel, then upgrading to the latest. I had the EXACT same thing.
#116257 - 14/09/2002 10:12 Re: discspace info w/ emptool v1.03 [Re: rockstar]
raphael
Loc: Austria
My problem with the hang is already solved with the downgrade, but I wonder
why there's no way to find out the free diskspace with the stable Linux utility
(w/o using a developer image).
Raphael Wegmann
raphael@psi.co.at
