#111215 - 16/08/2002 16:22
Can no longer sync my empeg??? Help!
Loc: San Jose, CA
When I sync it attempts to sync, quits, reboots the player. Does the same thing with jemplode and emplode. HELP. What's going on?
Adding Swap: 16596k swap-space (priority -6)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
hda4 is mounted.
hdc4 is mounted.
Restored terminal settings
Restart code received
Starting player
#111216 - 16/08/2002 16:29
Re: Can no longer sync my empeg??? Help!
[Re: eternalsun]
Have you done anything like changing your init?
#111217 - 16/08/2002 16:33
Loc: San Jose, CA
I'm using the preinit with hijack. why??
Calvin
#111218 - 16/08/2002 16:35
[Re: eternalsun]
Because if something were wrong with the way the player app were being called from this nonstandard init, then it might manifest itself in the way you describe.
See if you can blast a fresh Beta13 onto the player (without changing the init) and see if it synchs then. After that, add the nonstandard init back into place to see if it breaks.
#111219 - 16/08/2002 16:36
Loc: San Jose, CA
I also see the following text in the hyperterminal:
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v286 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Sun Jul 28 13:09:50 EDT 2002
empeg-car player (hardware revision 9, serial number 10101933)
Command line: mem=16m
Memory: 15072k/16M available (928k code, 20k reserved, 360k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9877c
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004200).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-230, ATA DISK drive
hdb: IBM-DJSA-230, ATA DISK drive
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
hdb: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:07:8
d
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg-preinit starting...
empeg-preinit complete
empeg init 0.8
Mounting proc
Starting player
khttpd: listening on port 80
kftpd: listening on port 21
opening display...
opening font file...
cannot open font file
Vcb: 0x4086d000
Calvin
#111220 - 16/08/2002 16:44
Loc: San Jose, CA
I tried putting in hijack 291, and syncing. Nothing. From emplode:
Failed to open database connection error 0x80040015.
I don't see how init could have something to do with this? I backed out the preinit.d scripts. rebooted and tried sync. Nothing. I'm working progressively backward.
Calvin
#111221 - 16/08/2002 16:56
[Re: eternalsun]
Have you installed a fresh Beta13 .upgrade file as I suggested?
edit: Also reboot your PC...
#111222 - 16/08/2002 17:03
Loc: San Jose, CA
I put in a fresh Beta 13.
Same thing! Argh!
Adding Swap: 16596k swap-space (priority -1)
h file or directory while determining whether /dev/hda4 is mounted.
h file or directory while determining whether /dev/hdc4 is mounted.
Starting player
Vcb: 0x4086d000
What's going on?
Calvin
#111223 - 16/08/2002 17:04
Loc: San Jose, CA
Yes. I installed a fresh beta 13.
Calvin
#111224 - 16/08/2002 17:15
Loc: San Jose, CA
Ok, I rebooted the PC. Still no luck. This is really, really bad isn't it?
Starting player
Vcb: 0x4086d000
Calvin
#111225 - 16/08/2002 17:36
[Re: eternalsun]
#111226 - 16/08/2002 17:43
Loc: San Jose, CA
I've tried the following. fsck on /dev/hda4 and /dev/hdc4 show CLEAN. Then I tried the following:
empeg:/# cd /
empeg:/# fsck /drive0
Parallelizing fsck version 1.19 (13-Jul-2000)
hda4 is mounted.
/dev/hda4: clean, 4806/228352 files, 2488799/7304850 blocks
empeg:/# fsck /drive1
ext2fs_check_if_mount: No such file or directory while determining whether /driv
e1 is mounted.
fsck.ext2: Is a directory while trying to open /drive1
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
empeg:/#
could this have anything to do with anything?
Calvin
#111227 - 16/08/2002 17:47
[Re: eternalsun]
I'm reasonably sure that if your player is a single-disk player, the "dev/hda4" error is normal and does not indicate a problem (since there is no dev/hda4).
Someone correct me if I'm wrong?
On my two-drive player I get the "Tried to mount /dev/hda4 as reiserfs but got error 19", which is also normal, I believe.
#111228 - 16/08/2002 17:48
No, I take that back. Hda4 is the music partition according to the developer info. Uh oh...
#111229 - 16/08/2002 17:50
Loc: San Jose, CA
Except... I have two disks.
There is nothing wrong with the player. No missing files. I can access drive0 and drive1 and look around freely. I can mount and unmount rw, ro. With hijack in I can ftp in and out. streaming is ok. Everything is ok, except sync from emplode.
Calvin
#111230 - 16/08/2002 18:09
[Re: eternalsun]
First, you don't want to fsck while they're mounted.
See if you can do a ``umount /dev/hda4''. Make sure the player application is stopped (that is, press `q' at the serial port) and make sure you're not cd'd into /drive0 anywhere. Then run ``fsck /dev/hda4''. If it claims that it's clean, try a ``fsck -f /dev/hda4''.
If any of those steps fail, don't go any further. Reboot and get back to us.
Then let us know what happens.
#111231 - 16/08/2002 22:33
ext2fs_check_if_mount: No such file or directory while determining whether [mount point or device] is mounted.
IIRC this error is normal, and due to fsck looking for which filesystems that are mounted in /etc/mtab, but the empeg doesn't have an /etc/mtab file...
#111232 - 17/08/2002 09:55
[Re: eternalsun]
Can you do an ls -l / so we can see if you've lost mount points?
M2a/ Smoke/60gb/Tuner!! Thanks Joe
M2a/ Blue10gb Thanks Ian!
#111233 - 19/08/2002 09:23
[Re: tarkie]
Loc: San Jose, CA
I don't believe I have. If I can go into drive0 and drive1 and observe all the files and nothing is wrong with them, then that wouldn't be the case right? I did an ls anyway here are the results:
empeg:/empeg/bin# ls -la /
total 31
drwxr-xr-x 15 502 220 1024 Jul 24 17:22 .
drwxr-xr-x 15 502 220 1024 Jul 24 17:22 ..
drwxr-xr-x 2 0 0 1024 Jul 24 17:18 bin
drwxr-xr-x 2 0 0 1024 Jul 4 2000 dev
drwxr-xr-x 5 0 0 4096 Mar 14 2001 drive0
drwxr-xr-x 6 0 0 4096 Nov 2 2001 drive1
drwxr-xr-x 4 0 0 1024 Jul 24 17:22 empeg
drwxr-xr-x 3 0 0 1024 Sep 15 1999 etc
drwxr-xr-x 2 0 0 1024 Feb 9 2000 lib
drwx------ 2 0 0 12288 Jul 24 17:22 lost+found
drwxr-xr-x 2 0 0 1024 Jun 2 1999 mnt
dr-xr-xr-x 28 0 0 0 Aug 17 00:42 proc
lrwxrwxrwx 1 0 0 3 Jul 24 17:22 sbin -> bin
lrwxrwxrwx 1 0 0 10 Jul 24 17:22 swapfile -> ./dev/hda6
drwxr-xr-x 2 0 0 1024 Apr 13 1999 tmp
drwxr-xr-x 4 0 0 1024 Feb 6 2000 usr
drwxr-xr-x 3 0 0 1024 Aug 28 1999 var
empeg:/empeg/bin#
Calvin
#111234 - 19/08/2002 09:26
Loc: San Jose, CA
empeg:/empeg/bin# cd /
empeg:/# umount /drive0
empeg:/# umount /drive1
empeg:/# ls drive0
empeg:/# ls drive1
empeg:/# fsck drive0
empeg:/# mount
/dev/root on / type ext2 (ro)
none on /proc type proc (rw)
empeg:/# fsck /dev/hda4
hda4 is mounted.
empeg:/# fsck /dev/hdc4
hdc4 is mounted.
/dev/hdc4: clean, 23839/228352 files, 2507951/7304850 blocks
empeg:/#
I rebooted, then tried to sync again, and it does not sync. It just reboots instantly when a sync is attempted. (!?)
Calvin
#111235 - 19/08/2002 09:36
[Re: eternalsun]
Right. It claimed both filesystems were clean. So go back, do it again, and add a `-f' option to fsck to force it to actually check the filesystems. That is, ``fsck -f /dev/hda4'', etc. Make sure you remember to umount them first again.
Note that I have no idea if this is actually where your problem lies or not.
#111236 - 19/08/2002 11:04
Loc: San Jose, CA
I am not able to sync tunes or playlists over. I am able to sync the config.ini file over. Strange right? If I attempt to sync over a tune or a playlist, and it fails in the following manner.
Calvin
#111237 - 19/08/2002 11:05
[Re: eternalsun]
Ah, it's not even trying to synch. It's not getting that far. It wants to do a disk check, and the disk check is failing.
#111238 - 19/08/2002 11:36
Loc: San Jose, CA
It's actually now a different error than before. So it's failing at a different place.
The following is a more detailed manual fsck, as per the FAQ, but alas, with the same results. I don't really see an error, except for the "no such file or directory" thing, but I'm told that is normal? So if that's the case, there is theoretically nothing wrong but it will not sync. :-( The good news is I can still *listen* to music, I can still operate the hijack web server, the hijack ftp server, etc etc. Nothing else seems out of the ordinary.
empeg:/# ro
empeg:/# umount /dev/hda4
empeg:/# umount /dev/hdc4
empeg:/# swapon /swapfile
empeg:/# fsck -fay /
hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1527/4096 files (0.5% non-contiguous), 9701/16384 blocks
empeg:/# fsck -fay /dev/hda4
hda4 is mounted.
/dev/hda4: 4806/228352 files (3.5% non-contiguous), 2488799/7304850 blocks
empeg:/# fsck -fay /dev/hdc4
hdc4 is mounted.
/dev/hdc4: 23845/228352 files (0.7% non-contiguous), 2507959/7304850 blocks
empeg:/# swapoff /swapfile
empeg:/# sync
Calvin
#111239 - 19/08/2002 12:14
[Re: eternalsun]
Loc: Louisiana, USA
Is there anything else he can try short of reformatting? Maybe a fresh install of emplode on a different computer?
Stu
#111240 - 19/08/2002 16:25
Does anyone know precisely what's happening during ``Checking Media''? I would think that it would be a cursory fsck, but, given that it's working properly from the command line, that wouldn't seem to be the case.
#111241 - 19/08/2002 16:26
[Re: eternalsun]
Do you have any third party software running on the empeg? If so, try disabling it all and then try to sync again.
#111242 - 19/08/2002 18:32
Perhaps not reformatting. Perhaps a fresh load of a standard upgrade would be enough. It would wipe the root partition, but leave the music intact. Question: are you syncing over ethernet, USB or (heaven forefend) serial?
#111243 - 19/08/2002 18:33
Loc: Los Angeles, CA
yeah, i was just about to say. i've encountered this problem when i ran a userland app that was on my music drive. if you kill -hup all the 3rd party, you should be able to sync.
#111244 - 19/08/2002 18:52
[Re: image]
Why SIGHUP? While, by default, it will kill a process, it's often overridden to do something else, usually restart. SIGTERM (15) would be a much more obvious choice to kill a process.
