Page 2 of 2 < 1 2
#109465 - 27/09/2002 17:49 Re: preinit v4 and launcher problems? [Re: Daria]
Warp10
Loc: Germany
Do you mean enjoy compiling or did you forget the attachment?
---------------------------- MK1: 00314 (4GB) MK2a: 030103104 (30GB) Installed in a BMW 323ti
#109466 - 27/09/2002 18:15 Re: preinit v4 and launcher problems? [Re: Daria]
Daria
This time for sure
116755-empeg-preinit2 (286 downloads)
#109467 - 27/09/2002 18:39 Re: preinit v4 and launcher problems? [Re: Daria]
Warp10
Loc: Germany
What did I do???
My player only says "Waiting..." and "0:00" in the lower right...
I replaced the file hijack in /bin with the file you attached and changed to 755. What's going on? Help!!!
Thanks.
#109468 - 27/09/2002 18:47 Re: preinit v4 and launcher problems? [Re: Warp10]
Daria
Do you have scripts in /etc/preinit.d?
#109469 - 27/09/2002 18:51 Re: preinit v4 and launcher problems? [Re: Warp10]
Probably has nothing to do with your init.
Check out this FAQ Entry.
#109470 - 27/09/2002 18:51 Re: preinit v4 and launcher problems? [Re: Daria]
Warp10
Loc: Germany
The M50gpsapp script. Nothing else.
I think the player goes into aux mode after booting.
Why is the new file so small compared to the old one?
#109471 - 27/09/2002 18:57 Re: preinit v4 and launcher problems? [Re: tfabris]
Warp10
Loc: Germany
Simultaneous posting...
Ok, it was the aux... pooh, shock...
No idea why it switched over, I've never set the source to aux.
There's no memory violation anymore! Thanks alot.
#109472 - 27/09/2002 19:01 Re: preinit v4 and launcher problems? [Re: Warp10]
The old one is statically linked for safety. Doesn't seem to make much of a difference in real life, though. I'll see if I can get these changes incorporated into the real source.
And, jaharkes, the reason I called /bin/sh from the system() call is because it was failing to work for me without doing that before, for some reason. I assumed it was the same reason I couldn't get a shell script to run as an init in the first place, which I couldn't figure out, so I ignored it here, too, but I didn't want to make people compile programs for startup purposes, so I explicitly called upon /bin/sh.
#109473 - 27/09/2002 19:29 Re: preinit v4 and launcher problems? [Re: wfaulk]
jaharkes
But /bin/sh is as far as I know only available on the developer image, so anyone with a regular image can install hijack, and upload preinit, but then nothing will work.
btw. I straced the difference between sh -c and sh and it looks like sh foo will fail when foo is not a shell script, while sh -c foo will actually exec foo when it is a binary, so sh -c sh foo should start sh, which exec's sh, which then parses the contents of foo. So the memory footprint isn't as bad as I expected initially.
#109474 - 27/09/2002 19:32 Re: preinit v4 and launcher problems? [Re: jaharkes]
Maybe the lack of /sbin/sh was the initial problem. Hadn't even considered that. I got lost in a series of odd weirdnesses. Preinit was supposed to be a quick hack. Didn't turn out that way.
Do I have your permission to use your changes to fold back into my release? I've got some other semi-released code that I should get around to releasing, too.
#109475 - 27/09/2002 19:32 Re: preinit v4 and launcher problems? [Re: Warp10]
jaharkes
You've got the gps connected to the serial port, and it is set to output nmea? I guess you didn't run hack_init on the player or you are running on AC, and as such the player isn't started with -s- and is actually trying to interpret the gps data as if they were commands coming in over the serial port.
Just a hunch
#109476 - 27/09/2002 19:36 Re: preinit v4 and launcher problems? [Re: wfaulk]
jaharkes
Ofcourse, especially the ones that fix the couple of allocation problems that valgrind found.
#109477 - 28/09/2002 04:24 Re: preinit v4 and launcher problems? [Re: jaharkes]
Warp10
Loc: Germany
Do you refer to my post in the 'gpsapp - less talk more action' thread? I've run hack_init and I use gps only in the car.
My player switched to aux after uploading the patched preinit. No gps connected at that time...
Page 2 of 2 < 1 2
