#107638 - 27/07/2002 10:36 emptris: hijack menu?
lothar
This post is probably more appropriate for the wish list forum, however...
What would be involved in making emptris "hijack menu friendly"?
cheers!
lothar
#107639 - 27/07/2002 11:21 Re: emptris: hijack menu? [Re: lothar]
jheathco
Loc: Mission Viejo, California
Um, I guess he released the source GPL, so when I get some time I'll attempt it, unless someone else wants to do it of course -- I don't have much time.
John Heathco - 30gig MKIIa w/ tuner module
#107640 - 29/07/2002 21:48 Re: emptris: hijack menu? [Re: jheathco]
lothar
Any progress?
#107641 - 30/07/2002 06:28 Re: emptris: hijack menu? [Re: lothar]
Dude, that was two days ago that he posted... Cut him some slack!
#107642 - 31/07/2002 22:22 Re: emptris: hijack menu? [Re: tonyc]
jheathco
Sorry, was up near Mammoth hiking Mt. Whitney... anyways... I haven't had a chance to take a look, but hopefully I'll have some time to get to it soon...
#107643 - 31/07/2002 22:49 Re: emptris: hijack menu? [Re: jheathco]
lothar
ahhhh Mammoth... heading up that way soon.
Take your time.
-lothar
#107644 - 02/08/2002 12:06 Re: emptris: hijack menu? [Re: lothar]
I've quickly hacked it to bind to the Hijack menu. It's here. The source code is a little untidy at the moment but I'll clean it up later.
- Trevor
#107645 - 02/08/2002 12:34 Re: emptris: hijack menu? [Re: tman]
Rad. Added to the riocar.org download section.
#107646 - 02/08/2002 12:40 Re: emptris: hijack menu? [Re: tonyc]
leftyfb
Loc: Lowell, MA
ok, I ran this, it did in fact add it to the hijack menu. Don't ask me why, but the 1st thing I did to test it was run empacman from the hijack menu, it ran emptris instead and upon going back to the hijack menu, empacman is gone. Luckily I hadn't added emptris to the preinit and a reboot brough it back.
and not a bug, but a little FYI, if your still in RW mode while running emptris, winning/losing just causes it to hang until to go back to RO mode.
Mk2a 30GB Blue. Serial 030102999
#107647 - 02/08/2002 14:35 Re: emptris: hijack menu? [Re: leftyfb]
Hmm... Okay. I'll have a look
- Trevor
#107648 - 02/08/2002 15:06 Re: emptris: hijack menu? [Re: leftyfb]
Hmm.... I'm not sure but it might be a bug in Hijack.
empacman and empan starts to freak if you start switching between both applications.
empacman and emptris goes funny...
emptris and empan also goes funny as well...
Can anybody else have a look to see if running two or more user applications in Hijack works?
I'll have a look about the RW problem in a sec.
- Trevor
#107649 - 02/08/2002 16:23 Re: emptris: hijack menu? [Re: tman]
jheathco
Made a small fork( ) update to give back the shell prompt.... check attached.
107665-emptris.zip (75 downloads)
#107650 - 02/08/2002 16:33 Re: emptris: hijack menu? [Re: jheathco]
Thanks. I'll update the package.
It may be easier to just use the daemon() call though as this will do all of the other steps necessary to become a daemon.
- Trevor
#107651 - 02/08/2002 16:46 Re: emptris: hijack menu? [Re: tman]
jheathco
I have same problems with applications freaking out.... they like run at the same time or something and hijack removes the menu entries.
#107652 - 18/08/2002 11:28 Re: emptris: hijack menu? [Re: jheathco]
lothar
ditto...
almost there.
