#106907 - 15/04/2003 13:59
Re: battery icon coming off standby
[Re: fusto]
Mine is still doing it. Only happens when the drives are spinning up. I'm wondering if it's related to what drives you have and how much power they draw?
Is anyone with only 1 drive getting this?
#106908 - 15/04/2003 14:01
[Re: SE_Sport_Driver]
Loc: Lummi Island, WA
I have 2 players both with one drive. 1 is a 10GB the other is a 20GB. They both show the icon coming off standby.
#106909 - 15/04/2003 16:36
[Re: fusto]
both of mine doing it with one drive.only when i turn on from stand bye,not when it boots.
040103958 60g
#106910 - 15/04/2003 16:49
[Re: fusto]
Loc: India
I have had the battery icon come on several times especially in the morning. So since my vehicle has a standard wimpy 65 amp alt. I had it upgraded to 195 amp G3? and for some reason still get the batt icon but just not as often, mostly in the morning. You could be suffering from short trip driving and it's not charging up the system each time or have the basic wimpy factory alternator. I do have 1200, 300 and 50 watt amps drawing off mine the guy that upgraded my alt. said if I needed more than 195 amps then somethings wrong, so I'm going to upgrade my stereo wires to 0/1 gauge, that should do it. Good luck with yours, check your wires.
#106911 - 15/04/2003 16:58
[Re: jwickis]
both of mine do it only when hijack is on them.
040103958 60g
#106912 - 15/04/2003 17:06
[Re: thrasher]
Loc: India
Hmmm I've never tried my player w/o Hijack on it, I love it too much. I'll try it on my spare to check mine as well I could also check, since I have both, MK2 & Mk2a for any differences.
#106913 - 15/04/2003 17:25
[Re: jwickis]
yes thats why I put it back on.I'm getting used to the icon now.I was just worried that it might hurt my drives.
040103958 60g
#106914 - 15/04/2003 18:14
[Re: jwickis]
definitely not wiring or alternator output.
Happens in my VW GTI and my Jeep identically. Jeep has an extra heavy duty alternator.
Problem disappears with the removal of hijack.
#106915 - 15/04/2003 18:20
[Re: fusto]
Oooo.. an idea: go into the Hijack menu, and set the "Hard Disk Detection" to "One or Two Drives". .. any difference in behaviour?
#106916 - 15/04/2003 18:34
I'm not allowed that option because HiJack detects that I have 2 drives, but maybe that will help the 1 drive peeps.
#106917 - 15/04/2003 19:01
still doing it.thanks for the idea though.
040103958 60g
#106918 - 16/04/2003 12:50
[Re: thrasher]
Yeah, here too.
#106919 - 16/04/2003 21:29
[Re: fusto]
Loc: India
Oh well I'm keeping Hijack on my player, small price to pay for cutting edge excellence. I think some of what I experienced was alternator related for it doesn't happen as often. The player doesn't pass out at stoplights anymore, just the icon appears w/no break in the sound. It'll soon be resolved I'm sure.
These guys are good.
#106920 - 21/04/2003 22:21
[Re: jwickis]
Loc: Auckland, New Zealand
bumping this for what its worth
im still getting this problem... for those semi-new to the thread, it is not a wiring problem or a current draw issue with your vehicle, or a 1/2 drive thing. or an issue with a component 'wearing out' since it is rectified if you go back to hijack 279 or earlier.
so it is some 'kernel talking to voltage sensor' thingy that got changed and hasnt been tracked down, or something like that.
anyway.. learnt to live with it like the others here.
[P] '86 Civic Si turbo
Mk2a 40Gb Smoke, 030102710
#106921 - 23/04/2003 08:02
[Re: lofreq]
Oh yeah, I've forgotten.. has anyone seen this on a Mk2a(RioCar), as opposed to a Mk2(EmpegCar) unit?
EDIT: seems to happen on mk2a's, now that I've read backwards in this thread.
Edited by mlord (23/04/2003 08:11)
#106922 - 23/04/2003 08:13
[Re: lofreq]
Okay, help me out with a theory here:
Can you reproduce this issue when the DIMMER settings are BOTH at 100% on the player (set dimmer too 100% with lights off, and again with lights on).
Next, try it again with BOTH dimmer settings at 50%.
Thanks.
#106923 - 23/04/2003 09:05
I was able to reproduce the issue in both instances.
#106924 - 23/04/2003 09:13
[Re: fusto]
Is button illumination set to OFF in the hijack menu (regardless of whether you actually have illuminated buttons..)?
#106925 - 23/04/2003 09:18
uh... no.
Hold on...
#106926 - 23/04/2003 09:21
Still get same same.
#106927 - 23/04/2003 10:18
[Re: fusto]
Okay, I'll put out v333 shortly, with the fake_tuner fixed (I think), and a possible fix for this particular problem..
#106929 - 23/04/2003 10:59
Well, the only possibilities are the diffs (posted earlier) from v279 to v280, which added synchronous access control to threads trying to write to the display controller. I suspect this "enforced serialization" is slowing things on in-car players for certain combinations of player setttings.
So, Hijack v333 now only enforces the access control when Hijack itself wants to write to the display controller -- to do this, it still has to track the player's accesses, and force those to wait when Hijack is in there, and vice versa.
Maybe this will help.
#106930 - 23/04/2003 11:04
#106931 - 23/04/2003 11:23
[Re: fusto]
Well, hijack v333 is out there now. Any change?
#106932 - 23/04/2003 16:59
Thanks for all your help and time on this.it's still doing it on both my players.it not a big deal it just stays on for a few seconds then goes away.Thanks agian.
040103958 60g
#106933 - 04/06/2003 08:39
[Re: thrasher]
Loc: Portland Or, U.S.A.
Just thought I'd bump this to see if there is any new news. I am having the same problems.
MKIIa 30gb in a 1998 Cadillac Catera
#106934 - 30/10/2003 17:01
[Re: LaneStar]
Bump.
Has anyone tried wiring the player directly to the battery to fix this?
#106935 - 30/10/2003 18:48
I had my whole system rewired and removed the tunner and it is not doing it any more.
040103958 60g
#106936 - 10/01/2004 15:40
[Re: fusto]
Okay, I have managed to reproduce this condition again (finally!) with a Mk2a in a Home Dock. But only when an Empeg Tuner is attached (special dock!).
Unplug the tuner, and all is normal. Plug in the tuner, and we get the battery icon off of standby condition. Happens with at least two of my three players (haven't bothered trying the third).
So.. I've been poking at the theory that the voltage takes longer to rise when a tuner is attached, and so if I simply disable powerfail detection a bit longer than the default of about 100ms after resume (from standby), the problem ought to go away again.
A 2-second delay definitely works for me! Now I'll try shorter delays. I may also revamp the entire "delay" mechanism, as currently the code (from original Empeg kernels) uses a 100ms in-line busy-wait loop, with interrupts disabled. Much better, at least for the coming from standby case, would be to simply schedule_timeout(HZ/10) for the same approximate delay in a friendlier fashion.
I'll poke at it some more, and release a fix (for my players anyway) in Hijack v352 later today.
