Page 2 of 6 < 1 2 3 4 5 6 >
#106847 - 30/07/2002 00:47 Re: battery icon coming off standby [Re: mlord]
lofreq
Loc: Auckland, New Zealand
ok, after an annoying amount of running from room to garage and back, and flashing in between, heres what ive found
at last post i confirmed that with 2.0b11 and hijack 278 there is no prob. with 280 there is the prob. i then went up to 2.0b13 (no hijack) - problem gone! i do believe some people have posted saying they had this issue after going to 2.0b13 - not so for me.
then i put hijack 286 onto my new working 2.0b13 - problem back again. mark brought back 279 so i tried that - problem gone again.
so it is an issue from 279-280. i looked at marks code attachment and nearly went immediately insane so i closed the browser window promptly...
i also saw that there is now 288 as the latest since yesterday, so i grabbed that as tried it as well, no luck, still battery icon rah rah.
my amps have a long turn on delay so i cannot tell if music starts immediately as the unit is awakened (even tho the display/LED are both fully dead...) so i cannot comment on that - however after doing it over and over i do feel that the sound comes on LATER, when the battery icon problem occurs, than when all is working normally. this isnt concrete tho.
anyway it seems to be an issue between 279 and 280 that has not yet been resolved in versions up till the latest (288 at time of post)
oh yeah - i did the 'force DC" modes and all that, it doesnt happen on AC power - only when docked in car.
mark if that narrows it down for you and youre bothered to have a nosey into it, you now have the controls sir
[P] '86 Civic Si turbo Mk2a 40Gb Smoke, 030102710
#106848 - 30/07/2002 03:02 Re: battery icon coming off standby [Re: mlord]
Dava
Loc: Bucks UK
I can also confirm that it happens between 279-280.
I never saw the scrambled screen that the changes were supposed to fix, so I would prefer it without
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
#106849 - 30/07/2002 04:02 Re: battery icon coming off standby [Re: mlord]
Laura
Loc: Greenhills, Ohio
For me it is a full 10-11 seconds before the music starts up.
Laura
MKI #017/90
whatever
#106850 - 30/07/2002 06:00 Re: battery icon coming off standby [Re: Dava]
The scrambled screen fix was not a part of v279-v280. It stays.
#106851 - 30/07/2002 06:55 Re: battery icon coming off standby [Re: Dava]
fusto
Loc: Lummi Island, WA
Ill second that confirm.
279 OK
280 No Ok...
#106852 - 30/07/2002 06:58 Re: battery icon coming off standby [Re: fusto]
Okay, now I'm (almost) as confused as poor Tony.
To make it easier to poke at the problem, I dug out a spare docking sled, and just wired up the yellow+orange to +12V and the black to GND. The aim here being to reproduce the in-car behaviour exactly, without having to wire-up the serial port behind the dashboard of my car.
Well.. no problemo. Works perfectly, in/out of standby.
Ugh.
#106853 - 30/07/2002 07:09 Re: battery icon coming off standby [Re: mlord]
tms13
Loc: Lochcarron and Edinburgh
To add fo the confusion - I think I see this here at work, in a docking sled with a dummy plug to put the player in AC mode. So I don't think it's a car-only issue.
It's fine at bootup, but if I put the unit into standby, then wake it again, the display doesn't appear for 2-3 seconds, then it appears with the battery icon for another 7-8 seconds.
No messages appear on the serial.
Like you, I have yellow and orange both tied to +12V and black to 0V. Amp control output, and the mute and lights inputs are all unconnected. Audio out and serial are through the docking connector, Ethernet via the socket.
Hijack v288.
Anything else you want to know?
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#106854 - 30/07/2002 09:45 Re: battery icon coming off standby [Re: tms13]
Could it possibly have something to do with the difference between 1-drive-units and 2-drive units? Or the difference between Mk2 and Mk2a units?
For reference, I have two drives in my player, it's a Mk2, and I don't have the problem even when in the car.
#106855 - 30/07/2002 09:47 Re: battery icon coming off standby [Re: tfabris]
SE_Sport_Driver
Good thinking. I have the problem in the car.
Beta 13, Hijack 288, Mk. 2a, 2 drives.
#106856 - 30/07/2002 09:49 Re: battery icon coming off standby [Re: SE_Sport_Driver]
leftyfb
Loc: Lowell, MA
Also have the problem in the car.
Beta 13, Hijack 288, Mk. 2a, 1 drive(30GB).
Mk2a 30GB Blue. Serial 030102999
#106857 - 30/07/2002 09:50 Re: battery icon coming off standby [Re: tfabris]
Dunno.
However, I did just notice that with the version I'm playing with now (no significant difference in the related parts, though), I only see the battery icon and delay when the engine is off.
In/out of standby with the engine running is just fine, thank-you.
So, I'm dropping the investigation.
On the off-chance that my slight tweaks since v288 may have fixed something, I'll leave them in for v289 (5-10 minutes from now).
#106858 - 30/07/2002 10:34 Re: battery icon coming off standby [Re: mlord]
fusto
Just tried HJ 289. Still have the same behavior. No change.
Battery icon and delay with car running or with car off.
My empeg is a mk2a also. Single drive 20GB.
Z~
#106859 - 30/07/2002 10:40 Re: battery icon coming off standby [Re: fusto]
Well, just for good measure I just tried my second unit (2 drive mk2a) in the car, and it works fine with/without engine running.
So I'm done with it, at least until it shows up again on my own units.
#106860 - 30/07/2002 17:44 Re: battery icon coming off standby [Re: mlord]
lofreq
i have a 2drive mk2a with the prob
anyway thanx mark for trying to help solve the prob
#106861 - 31/07/2002 03:53 Re: battery icon coming off standby [Re: tms13]
tms13
I've had another look at this, and I don't think it's related to the drives at all. I tried it in the car this morning, putting the player to sleep in tuner mode, and when I woke it up again I got the mysterious behaviour - blank screen for about 2 seconds and battery icon for a further 7 or 8 but without the disk icon appearing. Since the car's engine was running, the disks weren't active, and I never used to see this, I doubt that the supply voltage really is too low (though I don't have my multimeter handy).
I wonder if it's possible that the code that checks the supply level is confused by something. I don't know how it works in either hardware or software, but is it possible that thread scheduling or interrupt masking (including servicing higher-priority interrupts) is somehow making it difficult for the player to get a correct reading for a period of time?
Toby Speight
#106862 - 01/08/2002 02:06 Re: battery icon coming off standby [Re: tms13]
Dava
Loc: Bucks UK
Something else I thought of:
I seem to remember that Mark does not use initial=xxxx in his config.ini, do you lot that are having problems? I know I am.
I just wonder if there is some delay due to the initial codes???
....Nope just tried removing that and it doesn't help. It would make sense that it is something to do with the button illumination. I don't have lit buttons. Anyone else?
Edited by Dava (01/08/2002 02:26)
#106863 - 01/08/2002 03:36 Re: battery icon coming off standby [Re: Dava]
tms13
For the record, my player has
  • disk icons on
  • notify on
  • no initial command
  • restore Car visuals on
  • stock non-illuminated) buttons
Toby Speight
#106864 - 01/08/2002 07:28 Re: battery icon coming off standby [Re: mlord]
Dava
Loc: Bucks UK
Mark,
Do both your units have the button hack??
#106865 - 01/08/2002 07:40 Re: battery icon coming off standby [Re: Dava]
fusto
One of mine does and one doesnt.
Both display the same behavior in exactly the same way.
Z~
#106866 - 01/08/2002 09:23 Re: battery icon coming off standby [Re: Dava]
Nope, just one of them.
Still waiting for more button kits from Brian for the others.
#106867 - 01/08/2002 09:25 Re: battery icon coming off standby [Re: Dava]
For the record, I completely disabled (in the source code) the buttonLED illumination code, and it made no difference for me.
#106868 - 04/09/2002 13:13 Re: battery icon coming off standby [Re: fusto]
leftyfb
Loc: Lowell, MA
Has anyone solved this problem or had theirs just up and fix itself or anything? I'm still getting this and I miss the days where it would just come out of standby and immediately continue where I left off without having to wait a good 5 seconds or so for the screen to fade in, battery icon to pop on and finally for the sound to come through.
I am running Version 2 beta-13 with hijack 292.
#106869 - 04/09/2002 14:13 Re: battery icon coming off standby [Re: leftyfb]
fusto
Still happening here.
I choose to ignore it.
Well, as best I can, which is not so good.
You could run HJ 279...
That version for some reason doesnt cause this issue to occur.
Z~
#106870 - 04/09/2002 18:45 Re: battery icon coming off standby [Re: fusto]
MMorrow
Loc: Bellingham, WA USA
How did I miss this thread? I was this close to stopping in the shop to have what I thought was a failling battery replaced. The bbs saved me the cost of a new optima ... drinks are on me!
#106871 - 04/09/2002 19:45 Re: battery icon coming off standby [Re: fusto]
You could run HJ 279... That version for some reason doesnt cause this issue to occur.
And you're absolutely sure that 279 prevents the problem 100 percent of the time, while 280 causes the problem 100 percent of the time?
#106872 - 04/09/2002 20:13 Re: battery icon coming off standby [Re: tfabris]
fusto
I admit that this is the result of limited benchtop testing, but I did run HJ 279 for quite a long time after this thread ran its course. Couple of weeks at least. Never saw the battery icon once. Put 292 on a couple of days ago when I found that weird crashing bug with the auto changing visuals.
Have had the icon regularly since.
Conclude what you will.
Z~
#106873 - 04/09/2002 20:15 Re: battery icon coming off standby [Re: MMorrow]
fusto
Yeah, I almost bought a new battery too.
My empeg actually made me start to doubt my multimeter.
Must've been jealous.
Z~
#106874 - 05/09/2002 04:00 Re: battery icon coming off standby [Re: leftyfb]
tms13
Still happening here, and I'm just putting up with it.
It annoys me briefly every time it happens, but as soon as music appears(*) I'm happy again. I'm just like Homer Simpson, really. Ooo, look - shiny!...
(*) Is "appear" the correct word for audio? Bitt?
Toby Speight
#106875 - 05/09/2002 05:30 Re: battery icon coming off standby [Re: fusto]
avatarTX
Loc: Dallas Texas USA
I did stop by the auto shop and had my battery checked.. but it checked out fine so I was puzzled. Now I know otherwise..
Carl Aydelotte Dallas Texas USA empeg MKII 080000506 40gb-green
#106876 - 05/09/2002 14:55 Re: battery icon coming off standby [Re: tms13]
Well, since you asked ....
``Appear'' usually refers to a physical manifestation. So, out of context, someone might think that ``music appearing'' might refer to the sheet music being delivered. But, in your context, I think we understand what you mean. And I can't come up with a drop-in replacement. The closest I can think of would be ``emanate'', but I think it would sound a little awkward without a qualifying adverbial phrase (that is, ``as soon as music emanates'' vs. ``as soon as music emanates from the empeg'' or ``from the speakers'').
This is certainly picking nits, though.
