#105006 - 14/07/2002 11:41 centre screw in the back of the sled
Aragon
Loc: Cape Town, South Africa
Hi,
I was wondering for what the screw socket in the back of the sled was intended. I can't find any documentation on it. I thought maybe it's to attach a grounding wire, but is this necessary on an Mk2?
Thanks,
Aragon
#105007 - 14/07/2002 11:45 Re: centre screw in the back of the sled [Re: Aragon]
I think most people have used this to secure the back of the sled to the car body/dashboard once installed. I've not grounded my sled...
#105008 - 14/07/2002 11:59 Re: centre screw in the back of the sled [Re: Aragon]
The back screw is a for a certain special kind of mounting point in some cars. It supports the back of the chassis so that it doesn't droop down inside the dash on those vehicles.
Haven't you noticed that almost all other aftermarket stereos also have a screw hole in exactly the same place?
It can, if desired, also be used as an attachment for a grounding wire. However that was not its original main purpose.
#105009 - 14/07/2002 13:27 Re: centre screw in the back of the sled [Re: tfabris]
mtempsch
Like in the attached picture. Rubber knob mounts on stud screwed into cradle,
knob fits into hole at the centre back of the DIN opening. My Polo has a double DIN opening, empeg mounted at the top, you can see the hole at the back of the lower DIN opening. Of course, an ordinary back strap (perforated metal strip) can be attached if no such special arrangements exist in the car.
#105010 - 14/07/2002 15:26 Re: centre screw in the back of the sled [Re: Aragon]
Aragon
Thanks to all. My empeg is my first (and only) car stereo that hasn't been preinstalled before purchasing my car, so I'm not sure how other mounting sleds look
Regards,
Aragon
#105011 - 14/07/2002 15:28 Re: centre screw in the back of the sled [Re: Aragon]
thinfourth2
well trust me most of them don't look like an empegs espcially the ones that came with the mk2 which where stainless
#105012 - 18/07/2002 06:11 Re: centre screw in the back of the sled [Re: mtempsch]
JaBZ
Loc: NZ
Yea like how I did mine, attached.
JaBZ
#105013 - 18/07/2002 06:47 Re: centre screw in the back of the sled [Re: JaBZ]
ElectricD7
Loc: Indiana, USA
I used that point for a grouding wire since my sebrings ground wire wasnt part of the harness, but a separate wire with attached eye connector. Worked perfectly once I had the right screw and washer.
ED7 --------------------- 20G Mark2A SN#: 010101680 1997 Chrysler Sebring LXi
