#104068 - 09/07/2002 21:02 Winamp with Empeg, Sync error?
AlB
Loc: SF
I have my empeg all networked, it reads writes and accesses thru IE directly (very cool). But when I put the address of the player into winamp it comes back with a sync error?? I would assume since Ican connect thru IE that winamp would have no issues...but I am a rookie to this (amazed I've got this far!!)
I read Archeons issues but don't think I have a proxy server (set to detect automatically) and there is no place to exempt addresses.... running w2kpro and latest hijack
#104069 - 09/07/2002 22:05 Re: Winamp with Empeg, Sync error? [Re: AlB]
You don't put the address of the player into WinAmp.
You open the player's address in a web browser, then click on one of the play or stream icons on the web page that appears.
If you have properly associated MP3 and M3U files with WinAmp, the act of clicking on them in the web browser will open WinAmp and begin playing or streaming the file in question.
#104070 - 10/07/2002 01:32 Re: Winamp with Empeg, Sync error? [Re: tfabris]
thinfourth2
I don't know as there is a mini browser in winamp so this maybe what he means
#104071 - 10/07/2002 09:57 Re: Winamp with Empeg, Sync error? [Re: thinfourth2]
I can't figure out how to hand-enter an address in the WinAmp minibrowser, so I dont think that's it.
#104072 - 10/07/2002 09:59 Re: Winamp with Empeg, Sync error? [Re: tfabris]
DeadFire
The WinAmp minibrowser is really more like a skin for IE. Ctrl+O will pop up a box in which you can enter a URL.
#104073 - 10/07/2002 10:03 Re: Winamp with Empeg, Sync error? [Re: DeadFire]
Ah. OK, that works. Does not produce an error, I can click on songs in the Hijack web pages using the WinAmp Minibrowser just fine and they work.
I think what he was trying to do was to enter the Empeg's IP address into the "play location" box in WinAmp, rather than trying to surf to the web page.
#104074 - 10/07/2002 10:06 Re: Winamp with Empeg, Sync error? [Re: tfabris]
DeadFire
Oh. I'm pretty sure WinAmp will only stream mp3s from internet-type addresses. Probably HTTP only.
#104075 - 10/07/2002 10:12 Re: Winamp with Empeg, Sync error? [Re: DeadFire]
Right, WinAmp streams just fine from the HTTP server on the empeg.
The thing is, at the exact address HTTP://my.empeg.address , there's nothing to stream. If you enter that address into the "play location" box in WinAmp, you get the error message "Error syncing to stream".
You have to browse to the root web page and locate a specific song to play. Only after you click on one of those songs or playlists (for example http://my.empeg.address/?fid=101&ext=.m3u ), only then can it locate and play a stream.
#104076 - 10/07/2002 22:37 Re: Winamp with Empeg, Sync error? [Re: tfabris]
AlB
Loc: SF
Yeah THat was the issue, Still learning here.. Thanks Tony. Now Streaming away with Empeg on Winamp. This is about the coolest thing ever!! Couple of questions:
Building a SV24 box for my home entertainment (has TVout built in) and was wondering if there were a BIG FONT version of winamp that could be read across the room/ Or any other program.
Also is there any potential for hacking in to the empeg from outside? I have a Lynksys router with a NAT firewall AND Norton software. IS the Empeg vulnerable?
#104077 - 11/07/2002 03:54 Re: Winamp with Empeg, Sync error? [Re: AlB]
You can double the size of the Winamp dialog -- press Ctrl+D
#104078 - 11/07/2002 06:38 Re: Winamp with Empeg, Sync error? [Re: Roger]
Or click on the little "D" to the left of the spectrum analyzer.
It increases the size of the main Winamp window and the equalizer, but not the playlist. You can set the font size of the playlist seperately.
