#10334 - 30/06/2000 03:32 Mk II - any way to clear playlists without dev ima
steve
Loc: Cambridge, UK
Ok, so I've broken it already, and can't synchronise any more, -playing can only make it through one track before needing a power-off reboot. My database is rather broken. As there's no dev image for MK II (or is there?), is there a way to purge the database and start again? Downloading with ethernet is pretty fast, so it's not the end of the world. Is there a hidden "reinitialise" option in emplode?
(I'm prepared to wait 'til next week, but if there's an easy fix, I'd be happy)
Steve
#10335 - 30/06/2000 05:39 Re: Mk II - any way to clear playlists without dev ima [Re: steve]
I once had a database problem on my Mk1 like yours, and after a few reboots and synch attempts, the unit self-repaired its database and all was well. How many times have you tried to synch and reboot?
#10336 - 30/06/2000 06:40 Re: Mk II - any way to clear playlists without dev ima [Re: steve]
I've just uploaded the developer image temporarily - it's at http://www2.empeg.com/upgrades/test/car2-developer-beta11b.upgrade - this should help you in this case.
We'll be having a beta11c shortly when we can get our players to replicate the problem - at the moment both the 11b's we use on mk2's are working fine despite provocation!
#10337 - 30/06/2000 08:05 Re: Mk II - any way to clear playlists without dev ima [Re: tfabris]
steve
Loc: Cambridge, UK
Couple of dozen, using serial and 'net. No-go, I'm afraid...
Steve
#10338 - 30/06/2000 08:10 Re: Mk II - any way to clear playlists without dev ima [Re: altman]
steve
Loc: Cambridge, UK
Brilliant, I'll do that. Is there any information you want, or shall I just blast it?
(Failing that, I'll swap the unit out, if you think there's good debug to be had from it - it does crash nice & reliably...).
Just wondering - it's not 'cos I'm running a 2-CPU NT box, is it? Seems to cause some oddities in other code, too...
Steve
#10339 - 30/06/2000 08:21 Re: Mk II - any way to clear playlists without dev ima [Re: steve]
It should crash just as well on developer - the code is the same. The difference is that you can delete the database and force a rebuild, which is probably useful.
If it still goes wrong, then we'll get into the crashlogs & stuff.
#10340 - 30/06/2000 08:22 Re: Mk II - any way to clear playlists without dev ima [Re: altman]
steve
Loc: Cambridge, UK
Er, not that I can see....
Steve
#10341 - 30/06/2000 08:28 Re: Mk II - any way to clear playlists without dev ima [Re: steve]
Oops, sorry - missed out one level of directory...
http://www2.empeg.com/upgrades/test/beta11/car2-developer-beta11b.upgrade
