#102047 - 28/06/2002 09:00 wierd stuff in boot log
mrfixit
Well I finally hooked up the hyper terminal just to see what it could do and i found some wierd characters in the boot log..here ill show them..
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux....................................... done, booting the ker
nel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v276 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Wed Jun 12 09:25:39 EDT 2002
empeg-car player (hardware revision 9, serial number 10101521)
Command line: mem=16m
Memory: 14952k/16M available (1040k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005100).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:f
1
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...•Ô•j½Õ¹Ñ•‘É½½Ñ¡•áÑɁ™¥±•ÍåÍÑ•µ¥É•…‘½¹±å¹)5 chan
ge_root: old root has d_count=1
Freeing unused kernel memory: 4k init
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
What is that wierd stuff after " Press Ctrl-A to enter pump"
Could somone tell me please.
Ben
Ben
hijacked
#102048 - 28/06/2002 09:46 Re: wierd stuff in boot log [Re: mrfixit]
I think that's the baud rate of the serial port changing. Empeg guys, can you clarify?
#102049 - 28/06/2002 10:04 Re: wierd stuff in boot log [Re: tfabris]
mrfixit
So it is nothing to worry about then?.. the player seems to work fine other than the occasional lock up when uplaoding tunes, it seems to be the same thing alot of other people were talking about, when it gets to the last song it just says upload error 0x80072746. this doesnt happen very often and when it does it think it may be caused by one of the mp3s having a blip or pop or whatever that strange sound is when some of them are playing (only ones i get off the net mostly) the ones i rip are usually fine
Ben
Ben
hijacked
