#102022 - 28/06/2002 08:58 Trouble uploading tunes
Laura
Loc: Greenhills, Ohio
After spending the last 2 days replacing my motherboard and reloading Windows and everything else, now I am having problems uploading tunes to my MKl. I am using USB, it connects to the player and will upload the playlists but when it comes to the tunes it doesn't seem to be able to write them to the disc. I thought at first it was because the mp3 files became associated with Windows Media Player but changing them over to WinAmp didn't help.
Anyone have a clue where I should start?
Laura
MKI #017/90
whatever
#102023 - 28/06/2002 09:08 Re: Trouble uploading tunes [Re: Laura]
Terminator
Loc: Dallas, TX
What OS did you upgrade to?
#102024 - 28/06/2002 09:09 Re: Trouble uploading tunes [Re: Laura]
mrfixit
It shouldnt matter what program the mp3s are associated with, but if the mp3s are set to read only the rio might not like it. If you did a backup of your mp3s onto cdrom and them put them back on the pc most cd burner progs make all the files on the disk read only. If they are you can just select all of them in win explorer and right click and unchck read only, this way you can do them all at once. I hope this helps.
Ben
Ben
hijacked
#102025 - 28/06/2002 09:12 Re: Trouble uploading tunes [Re: Terminator]
Laura
Win98SE. It's the only one I have besides NT4.
Laura
MKI #017/90
whatever
#102026 - 28/06/2002 09:15 Re: Trouble uploading tunes [Re: mrfixit]
Laura
The files were on another hard drive and weren't changed at all. The files aren't read only, I just checked, they are archived.
Laura
MKI #017/90
whatever
#102027 - 28/06/2002 09:21 Re: Trouble uploading tunes [Re: Laura]
Laura
Also when I go to delete the songs since they won't upload, it moves them to a playlist by themselves. So I have to delete them from two different areas, the original playlist I am adding them to and the playlist it generates by itself. Very strange.
Laura
MKI #017/90
whatever
#102028 - 28/06/2002 09:24 Re: Trouble uploading tunes [Re: Laura]
mrfixit
Hummm that is strange, do your other players work ok now?
Ben
Ben
hijacked
#102029 - 28/06/2002 09:25 Re: Trouble uploading tunes [Re: mrfixit]
Laura
Good idea. I will give the other a try.
Laura
MKI #017/90
whatever
#102030 - 28/06/2002 09:28 Re: Trouble uploading tunes [Re: mrfixit]
Laura
The other player worked fine uploading, I did use ethernet on it and uploaded one song.
Laura
MKI #017/90
whatever
#102031 - 28/06/2002 09:36 Re: Trouble uploading tunes [Re: Laura]
Terminator
Loc: Dallas, TX
Try the other player on USB. Did you update your new motherboard with the newest BIOS and check the manufacturers site for new drivers and patches?
#102032 - 28/06/2002 09:36 Re: Trouble uploading tunes [Re: Laura]
mrfixit
Did you try the usb on the second player too? If it uploads using the other player it would seem that it is a prob with the mk1. wich ver of empload are you using on the players, the same ?
Ben
Ben
hijacked
#102033 - 28/06/2002 09:40 Re: Trouble uploading tunes [Re: mrfixit]
Laura
They both use beta 2.11b and the emplode matches the player versions. I'm trying to upload by serial now and I will try the other player on USB, maybe that is flaky.
Laura
MKI #017/90
whatever
#102034 - 28/06/2002 09:43 Re: Trouble uploading tunes [Re: Laura]
As was stated elsewhere in this thread, I would suspect the Windows USB drivers for that motherboard.
Whenever you re-install Windows, you have to spend some time getting all of the correct hardware drivers. One of the most common things you'll need is drivers for your motherboard chipsets, such as USB and IDE. If these aren't properly updated after a Windows re-install, you'll often have strange troubles like you described.
Ruling out hardware/disk trouble with the Mk1 is also a step you should take.
#102035 - 28/06/2002 09:45 Re: Trouble uploading tunes [Re: tfabris]
Also, after re-installing Windows, did you install Emplode BEFORE plugging in the player via USB? Sometimes if you plug the player in first, Windows will try to use one of its generic USB drivers instead of the proper Emplode driver for the player.
#102036 - 28/06/2002 09:48 Re: Trouble uploading tunes [Re: tfabris]
Laura
The correct drivers for the chipset are installed but I'll try removing them and reloading them. I got a song to upload through a serial connection so it must be the USB drivers. I put off reloading windows as long as I could but network neighborhood died on it last night so I pretty much had no choice.
Laura
MKI #017/90
whatever
#102037 - 28/06/2002 10:13 Re: Trouble uploading tunes [Re: tfabris]
Laura
Well, deleting the drivers in safemode and reloading them seems to have done the trick. The songs are uploading fine on USB. But now my network card has quit working again. Somedays I simply loathe computers
Laura
MKI #017/90
whatever
#102038 - 28/06/2002 10:22 Re: Trouble uploading tunes [Re: Laura]
mrfixit
Well Im glad to hear you got your songs uploading again, but sorry to hear about your network card, some times you just cant win... i still cant get my network card working right it freezes my dsl every 2min when its pluged into the pc. Ohwell
Ben
Ben
hijacked
#102039 - 28/06/2002 10:24 Re: Trouble uploading tunes [Re: Laura]
Some days? You're lucky, then.
#102040 - 28/06/2002 10:31 Re: Trouble uploading tunes [Re: tfabris]
Laura
Well, I'm a tech and work on them everyday but I hate working on my own. Network card is back up, just needed to be shut off for a bit. After 11 hours at this I think I am done, finally.
I think I will start a big upload and go outside and play. And I took the day off of work to get my own working
Laura
MKI #017/90
whatever
#102041 - 28/06/2002 11:23 Re: Trouble uploading tunes [Re: tfabris]
Laura
Well I thought I had it solved. Seems either the network card or USB will work, one at a time, but not together. No conflicts listed but that doesn't mean anything. They are not happy campers sharing something. I'll work on it later.
Laura
MKI #017/90
whatever
#102042 - 28/06/2002 12:00 Re: Trouble uploading tunes [Re: Laura]
Ahh.. perhaps they're not sharing the IRQ nicely.. maybe you can force them onto separate IRQs in the ControlPanel-System-Properties gizmo.
#102043 - 28/06/2002 14:19 Re: Trouble uploading tunes [Re: mlord]
Laura
Turns out they're not even sharing the same IRQ. I can't seem to make sense of this motherboard. I get one thing to work and something else craps out. IDE controllers aren't working right now. Geesh.
Laura
MKI #017/90
whatever
#102044 - 28/06/2002 21:03 Re: Trouble uploading tunes [Re: mlord]
Laura
Many hours later, they are on the same IRQ and working quite nice together. Makes no sense but hey, whatever works is ok with me. The USB would not work sharing an IRQ with a video capture card I have.
Laura
MKI #017/90
whatever
#102045 - 29/06/2002 06:42 Re: Trouble uploading tunes [Re: Laura]
mrfixit
Hey could you come over and fix mine?
Ben
mk2 20gig
hijacked
Ben
hijacked
#102046 - 29/06/2002 07:13 Re: Trouble uploading tunes [Re: mrfixit]
Laura
Sure, I'll be over in a few minutes.
PM me if you have any questions I might be able to answer and maybe there are a few tips I could give you.
Laura
MKI #017/90
whatever
