#100647 - 21/06/2002 08:00 Received Confirmation from digi-key - Connector
Neutrino
I received confirmation from digikey yesterday that all
of the components needed to build a sled connector had been shipped. Apparently they have them all in stock now for those of you that wish to build a connector.
#100648 - 21/06/2002 09:02 Re: Received Confirmation from digi-key - Connector [Re: Neutrino]
silamanajik
Loc: IL - USA
What part does digikey make? Is it the actual plastic piece on the sled with all the wiring?
#100649 - 21/06/2002 09:17 Re: Received Confirmation from digi-key - Connector [Re: Neutrino]
If it's not too much trouble, could you please post all of the part numbers you ordered?
#100650 - 21/06/2002 09:45 Re: Received Confirmation from digi-key - Connector [Re: silamanajik]
No, just the connectors themselves.
#100651 - 21/06/2002 10:15 Re: Received Confirmation from digi-key - Connector [Re: andy]
silamanajik
Loc: IL - USA
Cool I tried to get some from the original manufacturer and they were not very responsive. So like he said could you please post all the relevant information for ordering these?
#100652 - 22/06/2002 23:53 Re: Received Confirmation from digi-key - Connector [Re: silamanajik]
Neutrino
As odd as it may seem. I don't have the part numbers. I ordered these parts by using a link from the board. Those links don't work any more. I did receive the housing yesterday. It is Digi-Key part number H10109-ND and is the correct part. As the other items come in I will list the part numbers sorry.
#100653 - 23/06/2002 07:34 Re: Received Confirmation from digi-key - Connector [Re: Neutrino]
philp69
Loc: Long Island, NY
It looks like these are the Digikey P/N's:
H10109-ND Connector shell
H10085-ND Power Pins (2 per connector)
H10087-ND Signal Pins (22 per connector)
And here is Hirose's datasheet...
Phil
60GB Amber 10GB Blue
#100654 - 23/06/2002 08:31 Re: Received Confirmation from digi-key - Connector [Re: philp69]
silamanajik
Loc: IL - USA
That company, Hirose, is the same one I tried to buy from directly, but they would not respond to my emails. It is awesome you found a dealer for these parts. Good work!
#100655 - 23/06/2002 08:36 Re: Received Confirmation from digi-key - Connector [Re: silamanajik]
philp69
I can't take credit for finding Digikey, you have to thank Neutrino for that (thanks!). I just looked up the P/N's and put up some links...
#100656 - 23/06/2002 22:23 Re: Received Confirmation from digi-key - Connector [Re: philp69]
Neutrino
I can't take the credit either. The availablitliy of these parts was first posted by Shonky I believe. Thank you for relisting the part numbers!
#100657 - 24/06/2002 04:23 Re: Received Confirmation from digi-key - Connector [Re: Neutrino]
It was me originally and I did originally order some from Digikey but cancelled after I got a much better price here in Oz - MOQ was higher though. Also their 4-6 week lead time was obviously a little bit pessimistic.
That's what started the whole connector/harness buy. I am still away on business at the moment so don't have much time to check in here for a while. I should be back in Oz by the end of the week and will start to organize the actual buy. I am still on the hunt for suitable fuseholder and filter and possibly also the tuner connector, although I think they might be a bit of a lost cuase and I will supply the fues holder only and no tuner connector.
#100658 - 24/06/2002 09:12 Re: Received Confirmation from digi-key - Connector [Re: Shonky]
Derek
Loc: NRW, Germany
and besides which Paticks new tuner won't come with a connector - just a flying lead (to the best of my knowledge anyway).
#100659 - 24/06/2002 10:02 Re: Received Confirmation from digi-key - Connector [Re: Derek]
Wasn't it that he was going to just have leads coming out of the box with the connectors on the end instead of having the connectors mounted flush with the tuner casing?
If you don't have the plugs then you can just splice the wires together I guess if you're getting one of Patrick's new tuners...
- Trevor
#100660 - 25/06/2002 13:17 Question concerning quantity from digikey... [Re: Neutrino]
elperepat
Loc: Qc, Canada
I'm about to order connectors from digikey for a little project and would like to confirm quantity:
If you search for part number H10085-ND, unity price is 1.04$ (Can) each. On the bottom of the page, I read: Standard Package 100.
What do you think? If I order 10 x H10085-ND, will I get 10 or 1000 pins for a total of 10.40$?. 1000 pins seems ridiculous for 10.40$, but at 1.04$ for each pin, a connector will cost 25$ + 5$ for housing... Is that the expected price?
Anyone received pins from digikey and would like to confirm?
Thanks!
Elperepat
Patrick
#100661 - 25/06/2002 19:16 Re: Question concerning quantity from digikey... [Re: elperepat]
It probably means $1.04 each but you have a minimum order quantity of 100.
BTW: That sound's real cheap. Digikey US list about US$3.5 for a single unit down to US$1.5-2 for 50 or more.
#100662 - 25/06/2002 19:35 Re: Question concerning quantity from digikey... [Re: Shonky]
philp69
Unless it's different for shipments to Canada, you can order in 1 pc increments. I placed an order for 3 housings, 10 power pins and 80 signal pins and the prices (USD) on my order were $3.28, $0.611, $0.3804 each, respectively. I think the reference to 100 pcs is just the standard mfg supplied package quantity.
Phil
#100663 - 25/06/2002 19:44 Re: Question concerning quantity from digikey... [Re: Shonky]
dcosta
Loc: Massachussetts
These terms : pins, connectors and housings are all greek to me.
I am, however very interested in
"the thing on the back of the car mounting sled that has all the wires dangling from it."
whach can also be refferred to as
"the thing that the empeg connects to when you slide it into your dashboard."
I would like to buy 2 of them.
Shonkey, I think you've got me covered on this one,
Lemme know what you need for cash to make sure I get 2 of these, when the time comes.
I plan to make a couple home docking stations which, if they come out well,
I'll need more of the above described connectors
because I'll use them for more docking stations that I think I plan to selll here.
I think I mentioned that in another post somewhere.
-toodles
__________ davecosta Hijacked 60GB MKIIa 2.0b13
#100664 - 25/06/2002 20:22 Re: Question concerning quantity from digikey... [Re: dcosta]
I have you down. Hope to be back home on Friday and will start ordering connectors then. However I may need to stay a few more days (but I wanna go home.... ).
#100665 - 25/06/2002 21:18 Re: Question concerning quantity from digikey... [Re: Shonky]
did you decide if you were going to do assembled ones or not ?
#100666 - 25/06/2002 21:25 Re: Question concerning quantity from digikey... [Re: msaeger]
I will be doing them but for now it will be no noise filter, no tuner connector, no ISO connector and no mic socket. I will wire the tuner wires according to the colours on the current sled and supply the spare pins for the mic connector.
Look for an email next week about it with finalized prices too.
#100667 - 29/06/2002 08:59 Re: Question concerning quantity from digikey... [Re: Shonky]
Neutrino
Heres a picture of my first home made connector
#100668 - 29/06/2002 11:14 Re: Question concerning quantity from digikey... [Re: Neutrino]
Very nice. Coupla questions for ya - how long did it take to make, and how difficult is it for someone with only beginner level soldering skills? Also, does it require a special crimper?
#100669 - 29/06/2002 23:09 Re: Question concerning quantity from digikey... [Re: JBjorgen]
Neutrino
It is very simple to make. There is no soldering required. You can pick up a cheap crimper for under 20 bucks and make your own very easily. One of the crimpers I own that falls in this price range ia an AMP brand and says "Service Tool I" on the handle. There are no part numbers on it though. I think I got it at Rat Shack but am not sure.
#100670 - 30/06/2002 07:49 Re: Question concerning quantity from digikey... [Re: Neutrino]
I would solder them too if only because the crimped only ones from empeg had wires pull out
#100671 - 30/06/2002 10:35 Re: Received Confirmation from digi-key - Connector [Re: Neutrino]
AlB
Loc: SF
Thanks for the Post on connectors Just got confirmation of the shipment for my connectors from Diigikey! Lets see One for the living room one for the kitchen, one for the X5,M3,Mini Jeeze, better order more!! Oh yeah the Garage!! THank god there are resourceful people (all Y'all!) who search out these parts! Thank you Thank You Thank you
#100672 - 30/06/2002 11:41 Re: Received Confirmation from digi-key - Connector [Re: AlB]
rockstar
so what are we doing to make our own sleds now beyojnd the connector?
#100673 - 30/06/2002 12:02 Re: Received Confirmation from digi-key - Connector [Re: rockstar]
It's been reported in other threads that sleds from old pull-out car stereos can be retrofitted with some resourcefullness and a dremel tool. Of course, for a docking station, something workable could be fabricated from wood or sheet metal.
#100674 - 01/07/2002 08:23 Re: Received Confirmation from digi-key - Connector [Re: JBjorgen]
Neutrino
For those of you who wish to solder the connections. When you look at the pins you will see that there are two diffrent sets of flaps that are suppose to get crimped. The first set, closest to the pin, are for the bare wire. The second set, on the end of the connector are to be crimped over the insulation. The first set is for the electrical connection. The second set are to hold the wire so any flexing takes place away from the crimp. This is to reduce any chance of the wire breaking off. When you solder the connector, solder only were the wire is crimped for electrical connection and then only crimp the second set. If you solder the whole thing there is a greater chance that the wire will snap off at the beginning of the solder joint, due to vibration or wire movement. You will also need to be very quick with the soldering iron so as to not induce too much heat into the wire and cause srinkage of the insulation or wicking of the solder up the wire. Remember that the wire should be supple not stiff after the last crimp.
#100675 - 01/07/2002 23:44 Re: Received Confirmation from digi-key - Connector [Re: philp69]
nt4show
Loc: Califonia
Thanks a bunch for posting the site and part numbers. I really appreciate it
"If it aint broke don't fix it, tear it apart and see how it works"
#100676 - 02/07/2002 01:29 Re: Received Confirmation from digi-key - Connector [Re: nt4show]
Legoverse
Loc: Mesa, AZ
Yep. Thanks.
I just ordered two connectors and a bunch of pins.
Here is what is boils down to:
2 connector housings - $6.56 @3.28 ea.
50 small pins - $19.02 @ .38 ea. (ouch)
10 power pins - $6.11 @ .61 ea.
Total: $31.69 plus shipping. I opted for priority mail. There is an option for 1st class, but I wasn't sure of the weight.
I was forced to buy at least ten of the larger power pins - minimum order quantity. I only wanted 5 or 6 to cover myself for spares. So when I receive the order, I will post here and whoever is the first to request the extras (at least 4) gets them. (Free, via slow mail)
Save somebody having to order the power pins anyway.
Just did a little calculation. Digi-Key imposes a $5 handling charge if orders are less than $25. So whoever gets my free pins would still be compelled to buy two connectors and at least 49 small pins to come up to $25.
-- Terry K -- 30Gb Smoke / Toyota 4x4 30Gb Amber / Bounder RV Pants first, then shoes
