Boot into dos and execute the file in the attached zip. BE VERY CAREFUL with this file. If you use winzip DO NOT double click the file inside the zip. Extract it directly to a floppy and only execute it in DOS. Executing it will instantly kill the filesystem on whatever drive is attched. After that you can boot off the W2K cd and format it in either NTFS or FAT32. This is the easiest way, just be aware of the risk of executing this file.
To make a DOS boot floppy go to a DOS or Win9x machine and type the following:
FORMAT A: /Q /S
74603-HD_KILL.zip (28 downloads)
