I'm guessing Mark meant '&' and not '?'.
I tried a ? in the title of a tune, and it works properly. The other special characters you mentioned should definitely be escaped as you pointed out.
Here is a zip file with three sample stylesheets and some images. Some of this is adapted from Beaker's earlier post in another thread. Put the contents of this zipfile in your root directory, and rename the desired stylesheet to default.xsl
You can see, two of them use the XSLT 1.0 spec and one uses the Working Draft spec. Upgrade your browser or XML parser to be able to use the 1.0 xslt spec. My guess is more stylesheets will be written to that spec as there are more native functions, so it's easier to do a lot of stuff.
Mark, thanks for your efforts here. It works well. I guess I might have one request... The ability to override the default config.ini stylesheet. I was thinking if could be passed along with the quesry string. http://10.1.5.30/drive0/fids/101?.xml&xslt=newsheet.xsl or whatever. Is this doable?
Great stuff. Let's bust out some cool stylesheets.
Chris
71755-empegxml.zip (33 downloads)
