First i tried with a cheap 12v 1A power supply, but each time the disk was spun up, it got off and on again. So i connected the PC power supply, it's an 250W with nothing to feed but Riocar. It gives 12.3v. I suppose it is much better than the other i was using...
I forgot to say that first times it hanged, the disk sonunded like scatching, or parking/unparking the heads. Now it doesn't sound bad. The HyperTerminal says:
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com)ÿÿÿÿÿÿB„þóÄR*Näå^ Jm #
ô¤'§!wSS°ÆFck‡ÞÈÄžÆgþrýSŽþ†¥!ý‡ÿb…gó_BüÆÄ§Sækock΄ãäÛŽSfÛ aBÐ!ÆaZ@¼HH
%Çko‡Ëbó¶÷·ÈÞ)¢žSýw¦BÆrBs¢éÍk=§!Bðkb)Ì>bÏçÄPÆ
e000 v1.04â÷Þ§¹¬#ŽÏw
Copying kernel...
Calling linux kernel...
hda: IBM-DJSA-210, ATA DISK drive
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:7
b
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k initKernel panic: No init found. Try passing i
nit= option to kernel.
Each time it stops at a different point, sometimes it says it can't mount a partition and displays an error, or hangs as this.
I'm quite nervous!
Fantastic FAQ's, i've spent all this working day reading them ;-)
Thanks a lot:
Miguel Pelaz. Madrid.
60Gb blue MKIIa +PCATS tuner on a Seat León 20vt FR
