If they connect to what used to be the big fat ground trace, then that's the problem. You'll need to somehow restore a true ground to that side of each of the resistors.
They do connect to what used to be ground. Also connected to the same resistor on the gate end but on the flip-side of the board are those ceramic resistors which then attach to lines leading to the ICs.
