#347359 - 12/09/201114:44Re: Expanding the home LAN - access point questions
[Re: BartDG]
tfabris carpal tunnel
So that means I would have to connect it in one of the rooms surrounding the hall, immediately implying that the router would be located to one of the sides of the house and not centrally. Which would be no good for the reception on the other side of the house I'm guessing and essentially leaving me with the same problem, but horizontally instead of vertically in this case.
But it would only take a couple minutes to try it and find out. I'll bet that horizontally across the house would work fine in this case.
