Does the receiver show up on the server's list of recognised players (on the status page)?
No, only the softsqueeze clients are showing, no trace of slimrio.
Now, here are a few details on to the tcpdumps:
mars.local is the server,
192.168.1.101 is the rio receiver and
192.168.1.20 is the softsqueeze client
The first file (riotcpdump.txt) is the tcpdump of the rio getting it's ip from dhcp, then getting in touch with ssdp, then getting it's filesystem from the nfs server. Then, nothing. No request on port 3483.
Second file (softsqueeze.txt) is a tcpdump from a softsqueeze connecting to the squeezecenter. Traffic on port 3483 without problem.
Finally, last file (dhcpd.conf) is dhcp configuration. I tought the problem might be in here, but I can't find anything wrong.
If we don't find a solution, we'll try to do the same on an other computer, runing ubuntu 6.06. We'll see...
One last thing. in /proc/kmsg, my father's rio stop the log at "<4>Starting kswapd v 1.5", while mine continue further. Here's my receiver's log. nc doesn't seem to be "stable" as a lot of commands just hang it, so I suspect the abrupt end of files is linked to a nc crash.
<4>Linux version 2.2.14-rmk4-mercury19 (robin@victoria) (gcc version 3.4.2 (release) (CodeSourcery ARM Q3D 2004)) #1 Mon Jul 16 17:37:22 BST 2007
<4>NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp.
<4>IP-Config: Parameter #0: `192.168.0.101'
<4>IP-Config: Parameter #1: `192.168.0.23'
<4>IP-Config: Parameter #2: `111'
<4>IP-Config: Parameter #4: `255.255.255.0'
<4>IP-Config: Parameter #7: `off'
<4>Calibrating delay loop... 65.33 BogoMIPS
<4>Memory: 3156k/4M available (712k code, 20k reserved, 200k data, 8k init)
<4>Dentry hash table entries: 512 (order 0, 4k)
<4>Buffer cache hash table entries: 2048 (order 1, 8k)
<4>Page cache hash table entries: 1024 (order 0, 4k)
<4>POSIX conformance testing by UNIFIX
<6>Linux NET4.0 for Linux 2.2
<6>Based upon Swansea University Computer Society NET3.039
<6>NET4: Unix domain sockets 1.0 for Linux NET4.0.
<6>NET4: Linux TCP/IP 1.0 for NET4.0
<6>IP Protocols: ICMP, UDP, TCP
<4>TCP: Hash tables configured (ehash 4096 bhash 4096)
<4>empeg clps7212 audio driver initialized
<4>mercury display initialised.
<4>mercury infra-red support initialised.
<4>mercury rotary support initialised.
<4>mercury buttons support initialised.
<4>Probing for cs8900a
<4>eth0: cs8900 rev J found at 0x300 media RJ-45, IRQ 7 00 90 00 11 4f 1d
<4>IP-Config: Entered.
<4>eth0: using 10Base-T (RJ-45)
<4>IP-Config: Opened eth0 (able=0)
<4>IP-Config: device=eth0, local=b400a8c0, server=6500a8c0, boot=6500a8c0, gw=0100a8c0, mask=00ffffff
<4>IP-Config: host=192.168.0.180, domain=(none), path=`'
<5>Looking up port of RPC 100003/2 on 192.168.0.23
<5>Looking up port of RPC 100005/1 on 192.168.0.23
<5>VFS: Mounted root (NFS filesystem) readonly.
<4>Freeing unused kernel memory: 8k init
<5>init (1): unsupported llseek call standard
<5>bash (12): unsupported llseek call standard
<5>madplay (14): unsupported llseek call standard
<5>mad
Thanks for your help!
Patrick
riotcpdump.txt (1038 downloads)
softsqueze.txt (922 downloads)
dhcpd.conf (895 downloads)
Patrick
