The correct steps to do the stalk thing are in the same FAQ entry about the missed interrupts, here. Try the stalk entry in config.ini and see if the problem goes away.
Thanks. At least at home, the missed interrupts look sane (less then 20, not increasing over 30 minutes).
I managed to disconnect the tuner without pulling out the cage - I will watch if the problem is gone and report back.
