If it's non-standard, the "Advanced" button changes to "Restore". If the "Restore" button is not there, it's already set to the default. If you want to change it to something else, that panel is where you do it from. It ought to be reasonably obvious at that point.
This was under Windows XP Pro, so I suppose that it's possible that it might be slightly different elsewhere.
