#301970 - 10/09/2007 10:26
Re: Mark Lord's dock and correct config
Quote: I have a Mark Lord home dock and need to know what are the correct settings to use in order for the player to know it's in the dock and work with ethernet. I now have to use Hijack to Force AC mode to get it to work. But then when I put it in the car its still in AC mode. BTW I have a PCATS tuner in the car.
Go into the Hijack menu (long knob press), and set Force AC/DC Power Mode to Normal. It shoud then just work if this is really one of my docks.
Oh, you did mention that you have a PCATS tuner in the car. So in that case, you can use the tuner-id to detect car mode quite reliably. You should set the Force AC/DC Power Mode value to If tuner=3, Force DC/Car.
If you then have a second tuner for home use, just change the jumpers on that second tuner to something other than the default 3, and it will automatically select AC Power at home. If you have no tuner at home, then nothing extra is required.
