#297634 - 26/04/2007 10:54
Re: Multiple problems - i2c, lost interrupt
[Re: FireFox31]
Quote: .. ide_data_test: wrote 0x0000 read 0x0000 ide_data_test: wrote 0xffff read 0xffff ide_data_test: wrote 0xaaaa read 0xaaaa ide_data_test: wrote 0x5555 read 0x5555 hda: probing with STATUS(0x50) instead of ALTSTATUS(0xff) hda: IBM-DARA-212000, ATA DISK drive i.. ide0 at 0x000-0x007,0x038 on irq 6 hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63 .. Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 .. hda: status timeout: status=0xff hda: drive not ready for command ide0: reset: failed hda: lost interrupt hda: lost interrupt
The CS1- line is bad (stuck high) between the SA1100 and the drive, or the associated pull-up resistor on that line is bad. CS1- is pin 38 on the 44-pin IDE header.
EDIT: or possibly CS0- (pin 37) is stuck low.
Edited by mlord (26/04/2007 10:56)
FireFox31
26/04/2007 02:07
FireFox31
26/04/2007 02:36
FireFox31
26/04/2007 20:07
FireFox31
26/04/2007 20:32
FireFox31
26/04/2007 20:56
maczrool
26/04/2007 21:09
FireFox31
26/04/2007 22:07
FireFox31
26/04/2007 22:51
FireFox31
26/04/2007 23:12
FireFox31
30/04/2007 00:51
maczrool
03/07/2007 00:38
