#295071 - 12/03/200715:50Re: connecting receiver to server through wireless bridge and router
[Re: Dart Vader]
Roger carpal tunnel
Quote: Like I said, my wireless router is assigning a static IP to the server computer.
Can you clarify this point? It's probably not relevant, but normally, static addresses are entered on the computer. If you want the router to always assign the same address, that's usually called a reservation. Which do you have?
Quote: Could the disconnect be caused by the router-to-server connection being a static IP and the router-to-receiver connection being a dynamic IP?
Unlikely. Once the IP address is assigned, then the network can't actually tell the difference.
Could you tell us what those IP addresses are? What's the IP address of the router, of the server PC, of the wireless bridge and what's the address that the Receiver is reporting when it fails to boot up?
Do you have any kind of firewall in between the Receiver and the server computer? What happens if you plug the Receiver directly into the same switch/hub/whatever as the server?
