I need to get up to date on the new antenna. Please post back when you get yours.
I've had the 5-LNB dish since I got my first HR20. Mine is the AT9 model which was the first generation. There is now an AU9 model which is referred to as the "slimline." As you can see above, The AT9 is very large and significantly more heavy than the previous 2 and 3 LNB dishes. The mast is 2" OD now and two monopoles are required for wind stability.
The AU9 (slimline) has a similar setup, but the reflector is 30% smaller and the LNB assembly is one integrated piece.
