#276927 - 05/06/2007 16:24
Re: Aux in recording XM source
Quote: EDIT: An equally big question is, can it sample Aux-in while we play sound from software, or is sampling of aux-in only possible when aux-in is being played out?
When this discussion first came up (and the FAQ entry was written), my understanding was "no". I could be wrong about it, there are a lot of complexities surrounding this.
Well, tracing around a mk2a board, it appears that the cs4231a can sample from AUX-IN independently of whatever source is actually playing via the DSP.
Quote: The cs4231a chip can sample from aux-in --> that's how the aux-in visuals are done. Whether or not it can sample at sufficient quality for playback is another matter.
My understanding (again, a vague one) was that the sampling would max out at some low frequency, such as 7k or something. I don't remember the exact number.
The cs4231a documentation indicates that it can collect stereo 16-bit samples at various rates, including 48.0KHz and 44.1KHz (CD audio), depending upon the crystals/clocks it has been wired up with. I haven't bothered hooking up the LogicPort to measure those, but I don't think sample rate will be an issue for the hardware.
Edited by mlord (05/06/2007 16:27)
