I take it from this that the builder ran out of memory?
Freeing unused kernel memory: 4k initVFS: Can't find an ext2 filesystem on dev ide0(3,4).
mount: wrong fs type, bad option, bad superblock on /dev/hda4,
or too many mounted file systems
warning: can't open /etc/mtab: No such file or directory
umount: /drive0: not mounted
Making first drive...
mke2fs 1.14, 9-Jan-1999 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whetheno room for private writable mapping
r /dev/hderror: -12
a4 is mounted. /dev/hda4: Memory allocation failed while setting up superblock hdstress.cpp 189 ( 14): Poll result=1 on fd=5
hdstress.cpp 194 ( 14): Read a button press
Attached is the complete Hyperterminal output
277131-session.txt (234 downloads)
