#261233 - 25/07/2005 17:54
Re: Car-player v3.00, eleventh alpha release
[Re: peter]
And a reminder to those who have customized some things:
(1) If you use my ethernet upgrader utility to install v3a11, then you won't need to reinstall Hijack afterward, and the upgrade will happen much more quickly, as well.
(2) If you don't use upgrader, then the upgrade will overwrite Hijack, and you'll have to reinstall Hijack over (slow) serial afterward.
(3) The .upgrade file still includes the plain anna-vu visual, so you may want to redownload Tony's mucho macho vuback.raw into /empeg/lib/visuals to replace the default.
(4) If you are a fan of set_empeg_max_fid.v7 for dealing with LARGE playlists (including the down down down master shuffle), then you'll need to FTP it to the player and run it again after upgrading to v3a11.
(5) Any third party apps (such as empire and irattach and libopenobex-1.0.so.0) will probably need to be reinstalled after upgrading.
(6) If you have a largish ReserveCache=nn value in config.ini, you should substantially reduce it, as v3a11 now incorporates a hefty internal default for this. On my own 32MB player, I am using ReserveCache=32 now, which is still a lot, but going down to 0 increases the read-ahead stuttering too much for my liking.
It all seems to work great!
Edited by mlord (25/07/2005 18:58)
pgrzelak
25/07/2005 16:36
SonicSnoop
25/07/2005 16:47
robricc
25/07/2005 16:51
SonicSnoop
25/07/2005 16:52
robricc
25/07/2005 16:52
Mataglap
25/07/2005 16:52
Derek
25/07/2005 17:33
elperepat
25/07/2005 17:37
Defiler
25/07/2005 17:40
SE_Sport_Driver
25/07/2005 20:34
Mataglap
25/07/2005 20:53
oliver
26/07/2005 04:23
mrfixit
26/07/2005 18:38
oliver
27/07/2005 00:48
Re: Car-player v3.00, eleventh alpha release - Using Emplode 2.0
jarredduq
27/07/2005 02:22
oliver
27/07/2005 03:15
Memil
27/07/2005 16:45
jbradshw
11/08/2005 19:54
oliver
11/08/2005 20:00
jbradshw
11/08/2005 20:02
oliver
11/08/2005 20:09
jbradshw
11/08/2005 20:33
oliver
11/08/2005 21:55
jbradshw
11/08/2005 22:45
Foz
11/08/2005 21:29
Mataglap
25/07/2005 19:02
Mataglap
25/07/2005 19:20
genixia
26/07/2005 11:07
AndrewT
26/07/2005 11:36
robricc
26/07/2005 16:24
webroach
28/07/2005 02:05
Daria
28/07/2005 18:24
ninti
28/07/2005 18:37
pgrzelak
29/07/2005 09:55
Daria
29/07/2005 11:37
SonicSnoop
29/07/2005 15:59
furtive
31/07/2005 19:47
jnmunsey
02/08/2005 05:47
ninti
02/08/2005 15:06
Foz
02/08/2005 15:30
ninti
22/08/2005 14:16
ninti
02/08/2005 15:23
SE_Sport_Driver
03/08/2005 08:49
webroach
03/08/2005 10:10
JeffS
05/08/2005 10:52
JeffS
05/08/2005 11:29
JeffS
05/08/2005 11:31
Mataglap
05/08/2005 14:21
JeffS
05/08/2005 14:24
JeffS
05/08/2005 16:31
Daria
08/08/2005 12:00
g_man
28/07/2005 03:10
Daria
08/08/2005 12:15
rob
08/08/2005 16:14
JeffreyB
10/08/2005 07:28
JeffreyB
10/08/2005 08:49
JeffreyB
10/08/2005 22:57
ithoughti
14/08/2005 15:52
ithoughti
14/08/2005 16:56
ithoughti
14/08/2005 17:52
