Mine is in but the dash-surround pice is not finished. I pick that up next week. I'm going for an as clean as possible install and the guys at Magnolia are having a tough time with the bondo. They got the pice done but the rubberized coating on the rest of the piece bubels when primer or any paint is applied so they need a few more days to tweak the part.
I have the factory head unit going into a line-out converter into the aux in on the EMPEG and then a run to the amps in the back. It works OK, but needs some more tweaks as the radio soudns a bit weak.
I have the EMPEG tuner module but the audio from it was very quiet, so decided to go with the LOC for radio.
EDIT: my dimmer is not working. I know the harness has two dimmer lines. Which one is the correct one?
Edited by iank (11/07/2005 04:31)
