Where were you planning on putting the Empeg?
There is a pocket forward of the shifter below the enviromental controls. I'v seen the cd changer, normally in the trunk, mounted here. The molding that forms the pocket and mounts the accessary jack is removed to make space. You have to bend down to see the changer in that location. That qualifies as stelth, but makes it hard to read the display. If the sled was on drawer slides, it could be pulled out far enough to read and pushed back to hide it.
An alternate arrangement would be to mount it somewhat the why it appears. (its just setting propped up in the hole for the attached pictures)
-- Glenn
