I just got a Fujitsu MHL2300AT drive to upgrade my empeg with, and then I read that that specific model has had some pretty bad luck. Anyway I installed the drive and everything went fine until I plugged it in, and when it spun up I couldn't believe how loud it was. Note that the empeg was completely open, but even when I put the top back on later, it was still loud. The stock 10gb Travelstar I had in mine was silent .
I have a sound clip here (wav file). When you hear the first click, that is the power cable being plugged in. Then the drive spins up. For reference, the background noise you hear in the first couple seconds is the noise of my nearby computer fans. So this drive is pretty damn loud. Is that at all normal? There is no way I'm leaving a drive this loud in my empeg.
This may or may not be helpful, but here is the bootup info:
 ÿIf there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #17 Wed Jul 24 18:23:20 BST 2002
empeg-car player (hardware revision 9, serial number 30102826)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005680).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:0
a
Partition check:
hda: [PTBL] [3648/255/63] hda1 < hda5 hda6 > hda2 hda3 hda4
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...hange_root: old root has d_count=1
Freeing player.cpp : 385:empeg-car 2.00-beta13 2002/07/24.
Prolux 4 empeg car - 2.1434 Jul 24 2002
Vcb: 0x4086d000
edit: The following happened when the drive was being stress tested. It did spin up and down a few times, then went into a seek test, and after that, this kept repeating indefinately:
 Spindown failed (-1) errno=9 'Bad file descriptor'
hdstress.cpp 189 ( 29): Poll result=0 on fd=5
Stressing /dev/hda: Spinning down.
Edited by JonD (13/02/2005 21:26)
