#242172 - 22/11/2004 23:23
Re: Accessing shared machine at home??
[Re: hybrid8]
Quote: The only NetBIOS protocol I have is NWLink NetBIOS - it's not currently installed.
No, what I was talking about is not a protocol. It's a checkbox deep within the property pages of the TCP/IP protocol. If it's unchecked on either the client or the server, it will prevent someone from accessing the server's Windows shares.
Actually on recent Windows computers it's not a checkbox, it's a radio button giving three options:
- Disable - Enable - Automatic based on the DHCP server
If it's either disabled or it's set to Auto and the DHCP server disables it, then you'll get the problem you describe.
I don't know where the setting lies in Windows XP, but in Windows 2000 it's Control Panel, Network and Dial Up connections, Local Area Connection (rtclick get properties), select the TCP/IP protocol and get Properties, select the Advanced button, select the WINS tab. It's there at the bottom.
