I posted this problem before but it got mixed up in another thread about swapping boards between a MkII and a MkIIa, so let me start anew and summarize:
Victim: MkII empeg with 2 40 GB drives running v2.0Final and Hijack v383 with about 16.4GB free space
Problem: The drives stay spun up ALL THE TIME according to the drive activity icon... which in turn leads to overheating after about an hour or so use in car.
For a previous run down, check out this thread... but here's were i stand now.
Here's a screen grab of the icon that's always up (when it's not showing the W or reading icon) which is described in the FAQ as "Smaller icon with solid gray in center":
Boot log is as follows:
empeg-car bootstrap v1.00 20000601 (hugo@empeg.com)
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v383 (root@ibbm) (gcc version 2.95.3 20010315 (release)) #2 Fri
Apr 16 11:15:10 EDT 2004
empeg-car player (hardware revision 7, serial number 90000896)
Command line: mem=12m
Memory: 10960k/12M available (980k code, 20k reserved, 324k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9877c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005080).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IC25N040ATCS04-0, ATA DISK drive
hda: IC25N040ATCS04-0, ATA DISK drive
hda: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
hdb: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:80
Partition check:
Timezone: /usr/share/zoneinfo
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: /usr/share/zoneinfo/US/Pacific
Hijack: intercepting config.ini
hijack: removed menu entry: "Hard Disk Detection"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4058a000
spindown_chunk_cache_runner.cpp: 294:Filling up space (-18)
and that repeats at about one line a second... forever.
Last time I investigated this, i was getting an error:
Could not find CS4231A (version=80)
in the boot log, but that seems to have disappeared.
Here's a RAM check:
0000 empeg-car board test version 0.04 <hugo@empeg.com>
0100 ram test starting
0110 testing ic 1 (0-3mb, low word)
0120 testing ic 2 (0-3mb, high word)
0130 testing ic 3 (4-7mb, low word)
0140 testing ic 4 (4-7mb, high word)
0150 testing ic 19 (8-11mb, low word)
0160 testing ic 32 (8-11mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id IC25N040ATCS04-0
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 38
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
And here's my config.ini:
[hijack]
khttpd_root_index=/drive0/opt/khttpd/charcoalgray99/index.html
[output]
notify=1
[hush]
hushpercent=20
[display]
play_count=1
visual_names=1
caching=1
[volumecap]
enabled=0
[kenwood]
disabled=0
[ramp]
disabled=0
[menu]
quit=0
sort_playlist=0
[tuner]
region=us
[controls]
stalk_side=none
[Options]
Name=emp3g
[User Info]
Email=loren@******.com
Phone=415-***-****
Name=Loren Cox
[Network]
;@HOME DHCP=0
;@WORK DHCP=1
Gateway=192.168.1.1
Netmask=255.255.255.0
IPAddress=192.168.1.20
DHCP=0
[sense]
muteaction=1
mute=1
[power]
off_timeout=60000
[aux]
source=
title=
artist=
[synchronise]
seq_num=89
[wendy]
flag_amount=0
[custom]
wendy=
[searches]
amount=0
[VisualFavourites_AM]
count=0
[VisualFavourites_AUX]
count=0
[VisualFavourites_DSP]
count=0
[VisualFavourites_FM]
count=0
[shuffle]
deduplicate=0
I've reinstalled the firmware and hijack to no avail... as well as rebuilt the database by hand.
I'm stumped fellas... any ideas?
|| loren ||
