Hi -
I've never installed emphatic before. No luck so far. A few issues:
- I had to remove the "echo pass ...." part of install-emphatic.sh. For whatever reason passive mode doesn't work on mine.
- I didn't end up with ReserveCache=10 in my /empeg/var/config.ini. I added it manually, as without it I was getting do_try_to_free_pages errors from the VM system and eventually a kernel crash.
- After rebooting, I entered the hijack menu and selected emphatic. Had a problem:
Oops! Music FID ffffffff1 not found!
fid file not found, line 145
Oops! Music FID ffffffff0 not found!
fid file not found, line 290
emphatic(11): memory violation at pc=0x02003624, lr=0x4002810c (bad address=0x0
pc : [<02003624>] lr : [<4002810c>]
sp : bffffc04 ip : bffffad8 fp : bffffe28
r10: 40145128 r9 : 0200254c r8 : 0204b5ac
r7 : 02001e80 r6 : 4000c2a8 r5 : 00000001 r4 : 0205ea2c
r3 : 0205eaa8 r2 : 00000000 r1 : 02063c90 r0 : 00000000
I didn't select the initialize ratings option in the config, if that's related.
The whole log is attached.
Let me know if there's anything you want me to try.
227574-y (263 downloads)
