> maybe check if the file exists, and if it doesn't check the other drive?
I thought I programmed it this way :
check if file exists in /drive1/fids
if so , change directory to /drive1/fids
if not change to /drive0/fids
read file <fidnumber>
It seemed I was changing directories correctly, but was reading an absolute filename ("/drive0/fids/<fidnumber>")
It is fixed now
The process list in system-info has also been updated; it now shows the correct terminal name and vsize and rss now report in Kb.
I've attached the new executable and source to this post; install.sh has been updated...
Frank van Gestel
1-22002-displayserver.zip (40 downloads)
Frank van Gestel
