Oh, ok. Well if that's the case then I must have something set wrong in my config. If I force DC power mode and set up a terminal program to read at 4800 I get the following when I reboot.
‚„Âã Þ¿ J ,Ç©¦ÃÉ€/,ÜÍÏüî•‹BOŠ:„j­‹àÔþ9”|Ä*‹6 à
Œˆ *;"¼Cû­t†©+Ê­Îû+) ý Ú è Ú è ý+cÈÊ㹇cmJÜ•þþ€€'­}ï   ¨ùO
fûÞ¾(ú({ö)ëB²nj³K)kC/Jb¯Æjyˆ Bü…Õ‘rate: 4800, disabling logging
The garbage at the beginning is the Linux startup data at 115200 then I see "rate: 4800, disabling logging"
This must be turning off the data output, how do I turn it back on? My config.ini is
[hijack]
suppress_notify=0
[output]
notify=1
