I am trying to install a Toshiba MK1214 HDD on my Mark I player and I am stuck on the initialization process. The hardware works OK but when I try to "build" the drive I get an error during the "Selecting Pump" section. This happens no matter which version of the "upgrade" file I use.
The drive works perfectly OK when I install it in a laptop. I have tried deleting the DOS partition from the drive but I get the same response.
Attached is the Hyperterminal log from boot when the drive is connected. You can see the drive is correctly identified but then there is an "unexpected interrupt".
Before I give up in the drive, can anyone think of what I am doing wrong?
Thanks,
Enrique Rodriguez
ercerc@hotmail.com
184235-MK1214GAP.txt (233 downloads)
